@chris I just found out that the Philio PAT02-A alarms don’t work. There was an alarm_general channel configured, but the device has an alarm_burglar and an alarm_flood channel. I’ve compiled my own binding with those channels and the alarms worked perfectly. I’ve just added the changes to your device database and requested a review.
I also don’t know what the sensor_binary channel does. Do you know what this channel does?
Edit: I found out that the sensor_binary channel it the case tamper alarm.
Sometimes the same ‘events’ are linked to multiple command classes - so often the sensor_binary is linked to the main alarm type (eg movement if it’s a PIR sensor, door open if it’s a door sensor etc). I don’t know specifically for this device though.
