the Philips Hue binding only finds the channels “brightness” and “color temperature”. I tried serveral times. Made clean installations. I tried everything. It is absolutley impossible to get the On/Off switch, etc. Why? Is this a known bug in the latest stable versions of openHAB 2.1.0 or Hue Binding 2.1.0 ? My Philips Hue system is working great with any other app and smart home system. It is the 2nd Generation (square) with latest firmware 1707040932.
I only get “brightness” and “color_temperature” for a default “Color Temperature Light” and for an “Extended Color Light” I only get “Color” and “Color Temperature”. “brightness” is missing there. “effect”, “alert”, etc. is missing for all lights. And “switch” too, and “Switch” is what I am looking for instead of using a workaround to switch the light on/off with brightness. How I switch on/of an Extended Color Light then? With Color?
The concept is, the more complex functionality inherits the less complex.
A simple on/off light/switch has a switch channel.
if you are able to control brightness, it inherits the switch capability
if you are able to control color, it inherits the brightness with switch capabilty
Using this concept allows for more simple configuration. You just need to put one colorpicker into the UI to give full functionality. (A colorpicker is able to control brightness and (with that) on off as well).
