Hi OpenHAB’ers,
I’m a newbie to this world and try to learn how to swim
I’m using OpenHAB 2.5.5 and MQTT/mosquitto 1.6.10 and zigbee2mqtt 1.13.0 on a Raspberry Pi with some 15+ MQTT controlled devices. So far, so good. Now I want to use a Philips Hue Dimmer Switch to control an Osram Lightify bulb and a Ucomen switch (current Tasmota firmware 8.3.1 patched). All three devices are available using MQTT and controllable via openHAB. Where do I want to be? The remote ON/OFF switches both devices on/off. The remote dimmer brightens/darkens the Lightify bulb and the plug is switched ON if dimming value > 0.
My current rule:
rule "LivingDining Lamp Remote Control on/off"
Item iGFL_LivingDining_LampRemoteControl_RemoteControl_PhilipsHueDimmerSwitch_action received update
switch(triggeringItem.state.toString) {
case "on-press": {
iGFL_LivingDining_FloorLamp_Lamp_OsramLightify_power.sendCommand(ON)
iGFL_LivingDining_Trolley_Lamp_Ucomen_power.sendCommand(ON)
case "off-press": {
iGFL_LivingDining_FloorLamp_Lamp_OsramLightify_power.sendCommand(OFF)
iGFL_LivingDining_Trolley_Lamp_Ucomen_power.sendCommand(OFF)
The things:
Thing topic tGFL_LivingDining_FloorLamp_Lamp_OsramLightify "Floor Lamp" @ "Ground Floor Living Dining"
Channels:
Type switch : state "Power" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/state", commandTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/set/state", on="ON", off="OFF" ]
Type number : linkquality "Link Quality" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/linkquality" ]
Type dimmer : brightness "Brightness" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/brightness", commandTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/set/brightness_percent", min = 0, max = 100, step = 1 ]
Type string : update_available "Update" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/FloorLamp/Lamp/OsramLightify/update_available" ]
Thing topic tGFL_LivingDining_LampRemoteControl_RemoteControl_PhilipsHueDimmerSwitch "Remote Control" @ "Ground Floor Living Dining"
Channels:
Type string : action "Action" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/LampRemoteControl/RemoteControl/PhilipsHueDimmerSwitch/action" ]
Type number : linkquality "Link Quality" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/LampRemoteControl/RemoteControl/PhilipsHueDimmerSwitch/linkquality" ]
Type number : brightness "Brightness" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/LampRemoteControl/RemoteControl/PhilipsHueDimmerSwitch/brightness", min = 0, max = 255, step = 1 ]
Type string : update_available "Update" [ stateTopic = "zigbee2mqtt/GFL/LivingDining/LampRemoteControl/RemoteControl/PhilipsHueDimmerSwitch/update_available" ]
But how do I use the the brightness values in case of a brightness change?
Thanks for any helpful ideas
Berny
