Hi!
I’m an absolute openhab newbie. I have added my philips hue as a “thing”. I want to realize a very slow fade from one color to another over a duration of about 1 hour. How to do this?
Thanks!!
Hi!
Thanks!!
youll need some item definitions in .items files. see http://docs.openhab.org/configuration/items.html
youll need a rule to control your items. see http://docs.openhab.org/configuration/rules-dsl.html
youll need a sitemap with a switch to start your hue fading. see http://docs.openhab.org/configuration/sitemaps.html
quick & dirty example of fading a color hue bulb:
// Items:
Color Your_Lamp "Lamp" <colorwheel> { channel="hue:0210:your_huehub:your_id:color" }
Switch Hue_Fading "Hue fade"
DateTime Hue_Fade_Next
// Rules
var Timer timer = null
// Start/stop fading
rule "Start Hue Colors fading"
Item Hue_Fading changed
if (Hue_Fading.state == ON) {
// set a timer to sligtly change the color again and again
timer = createTimer(now, [|
Hue_Fade_Next.sendCommand(now.toString)
if (timer != null) {
timer.reschedule(now.plusSeconds(1))
else {
timer = null
// Fade a bit.
rule "Hue Fade Next"
Item Hue_Fade_Next changed
// get your current color
var hsb = Your_Lamp.state as HSBType
// change it a little bit
var DecimalType hue = new DecimalType(hsb.hue.intValue % 360 + 1) // 0-360; 0=red, 120=green, 240=blue, 360=red(again)
var PercentType sat = new PercentType(hsb.saturation.intValue) // 0-100
var PercentType bright = new PercentType(hsb.brightness.intValue) // 0-100
var HSBType newHsb = new HSBType(hue,sat,bright)
// set the new color
Your_Lamp.send(newHsb)
// Sitemap
Switch item=Hue_Fading
change fading time playing with the reschedule parameter:
EDIT: completed when in “Start Hue Colors fading”
