Phillips Hue - HSB stopped working
Hello all,
Platform information:
  • Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
  • OS: OpenHabian
  • openHAB version: openHAB 3.4.2
Issue of the topic
A couple of weeks ago all my rules sending commands to Hue lightbulbs using HSBType variables converted to string stopped working. I don’t know if the Hue Bridge received an update.
The logs don’t show abnormal messages.
Items configuration
Color Toilettes_C "Toilettes" (gToilettesEtage, gLCouleur) {channel="hue:0210:00XXXX:bulb7:color", expire="2m,command=0"}
DSL Rules code related to the issue
Rule to define HSB value depending of time of day:
import org.openhab.core.library.types.HSBType
rule "lumiere dimmer nuit"
	Item Pr_Mode_Nuit received command
	var h = 0
	var s = 100
	var b = 1
	if(Pr_Mode_Nuit.state == OFF)
		h = 32  // 60
		s = 20  // 73
		b = 30 // 30
	else
		h = 0
		s = 100
		b = 1
	var DecimalType hue = new DecimalType(h) // 0-360; 0=red, 60=yellow, 120=green, 240=blue, 360=red(again)
	var PercentType sat = new PercentType(s) // 0-100
	var PercentType bright = new PercentType(b) // 0-100
	var HSBType light = new HSBType(hue,sat,bright)
	Pr_Dimmer_Light.sendCommand(light.toString)
Rule sending HSBType value to Hue lightbulb:
rule "lumière toilettes"
	Item HuePresence received update
	if (HuePresence.state == ON)
		var HSBType light = new HSBType(Pr_Dimmer_Light.state.toString)
		Toilettes_C.sendCommand(light.toString)
Log output
2024-08-04 18:06:53.503 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Toilettes_C' received command 0,0,1
2024-08-04 18:06:53.518 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Toilettes_C' predicted to become 0,0,1
2024-08-04 18:06:53.526 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Toilettes_C' changed from 0,0,0 to 0,0,1
Do you have an idea why this is happening?
Is there a work around?
Thanks in advance,
Ludovic
I guess this is the same issue as below. Nothing special was changed in the Hue binding so I suppose something changed in OH core rules parsing…
Thanks for the link and the explanations.
I do think that the issue is coming from the new update of the Hue Bridge.
I posted a workaround (post #13) based on the details of post #2.0.
Cheers,
Ludovic
