- Platform information:
- Hardware: RaspBerry Pi 3 Model B Plus Rev 1.3
- OS: Raspbian GNU/Linux 11 (bullseye)
- openHAB version: openHAB 3.3.0.M6
- Notes: System controlled by openHABian latest release. All other SW latest versions installed with openHABian
- Issue of the topic: Phoscon app (deConz) is running, but cannot be accessed through the web-interface on port 8081 after upgrade to M6 and reboot
What is the output of
netstat -tulpn | grep -i deconz
and
ps -ef |grep -i [d]econz
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 367/deCONZ
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 367/deCONZ
udp 0 0 0.0.0.0:1900 0.0.0.0:* 367/deCONZ
root 365 1 0 Jun06 ? 00:02:20 /bin/bash /usr/bin/deCONZ-update2.sh
root 366 1 0 Jun06 ? 00:06:22 /bin/bash /usr/bin/deCONZ-WIFI2.sh
openhab+ 367 1 1 Jun06 ? 00:22:19 /usr/bin/deCONZ -platform minimal --http-port=80
Somehow the port 8081 that was recommended to be defined when I installed deconz using openHABian was changed back to 80 during the upgrade process from 3.3.0.M5 to 3.3.0.M6
Problem solved, but I don`t know if this changed will cause other problems
I doubt that this is caused by the update of openhab. I could imagine that this happens due to updates of openhabian depending on your setup.
Did you create a file /etc/systemd/system/deconz.service.d/override.conf to define the changed port ?
No, only used opanHABian to install and configure deconz/Phoscon App
The intention of the file
is to define ports that are different from the default ports.
In my case the file looks like:
[Service]
ExecStart=
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=8090 --ws-port=9443
Changes at other locations might be overwritten by updates of the modified files.
