opnehab _latest imge installed 64 bit = openhabian-pi-raspios64beta-202007302224-git0290f04-crc93729328.img
Issue of the topic: Can SSH but can not HTTP into openhab
I have seen some posts with the PI4 with 8gb of ram but my issue is:
I bought the PI4 B 8gb, loaded as normal the production image but had so many issue like hanging, not booting and finally could ssh but no UIs. I called got a replacement thinking the unit was defective now same issue. So research several hours now loaded the above 64 bit image, loaded fine, ssh OK but still can not web into it. Took my SD from my home system (PI4 B 4gb) placed it in the new PI same issue, I can not web into it.
Any help would surely be helpful for me to keep what hair I have leftâŠ
I have loaded several images, to now find out I can ssh is just fine, but the web access doesnât work. I just discovered if I use âsudo openhab-cli startâ then I can get into âopenhab:8080â to work But âopenhab viewer UIâ still doesnât work, for example. Please understand I am not programmer but I have been using Openhabian for 2 years now and have a fair home automation system. I have 2 new PIs 4 B with 8gb that reacts the same. It appears the Openhabian images need some help with regards to this new PI. My basic question does anyone have a new PI 4 B with 8gb working with what image? ZRAM appears ok based on the ssh splash screen.
Thank you denominator, I used that image I just didnât edit the config file. I will do this tomorrow and let you know. Frustrating when only increasing RAM can cause so much havoc.
Sorry denominator, did as you suggested 2Xs. Same problem, web services doesnât work until I run âsudo openhab-cli startâ but I want to say this doesnât fix all the problems, just access to UI. Another interesting function. Using ssh, openhabian-config, I installed 21 - log viewer, then the PI rebooted. Geezz
I loaded Raspian and it works top notch, but I will miss my Openhab, hope the image get adjusted soon. I want to upgrade my home âopenhabâ system. I can wait a little longer. Thanks guys for the help.
You meant to say you loaded Raspbian and do not use ZRAM right?
The crash issue is not in openHABian but in Raspbian, but it only surfaces when you enable ZRAM which has advantages but is not a must.
So why donât you just disable that as @denominator and I told you to (see above).
You can still add it later when the kernel issue gets resolved.
OK I will, I am just worn out from the hours of trying to find the cause, buying a second PI because I thought I had defect hardware. My thought if we know this is an issue for the 8gb PI then could we just make ZRAM an option to be added in Openhabian-config for dummies like me? As it is there, just donât make it active per default? THANK YOU for all your help!!!
When you read the docs you will have noticed thereâs a Debug guide.
As already mentioned youâll need (at least) clonebranch=master in openhabian.conf.
