Is is possible to use more than one receiver in the pioneeravr binding? I’ve tried adding a second IP / port to the config file, but all of the items seem to map to whichever receiver is defined last.
pioneeravr:livingroom.host=192.168.1.51 pioneeravr:livingroom.port=23 pioneeravr:loft.host=192.168.1.52 pioneeravr:loft.port=23
@Spilota I had this same problem myself but never found a proper solution, moved over to OH2 where the pioneeravr binding supports multiple receivers.
@tobo Thanks Tobias. Does the OH2 binding support Zone 2 commands (on / off and volume)?
@Spilota
Doesn’t look like it, don’t use it myself either. Could be requested I guess.
https://github.com/openhab/openhab2-addons/tree/master/addons/binding/org.openhab.binding.pioneeravr
