I am using the PioneerAVR config binding in my OH2 set up to control my VSX-1120 receiver. It is working flawlessly. However, I have a two room set up and would like to be able to send the “1SPK” and “SPK” commands to switch between the speakers between the different rooms. There doesn’t seem to be an obvious way to do this with this binding.
I have experimented by sending the command with the TCP binding but this seems to cause errors through the contention with the Pioneer binding (I guess because they are both tied to the same IP address and port). Which ever binding interacts with the receiver first after boot has the priority and the other binding then flags errors.
I saw that the original legacy 1.x Pioneer binding supported this function (and many more) but I don’r really want to go ‘back’…
