I was wondering if anyone would know how to do this. I would like i specific song to play when one of my tp-link smart plugs turns on through a chromecast audio. Does anyone have any idea how to make this happen or if it is even possible through a rule or a script? Thanks.
This may depend on how you have your tp-link plug configured to work with OH, if OH is the main control point add a rule for when the plug turns on stream song to chromecast.
I don’t have chrome cast so I’m not familiar with how you cast to it from OH, and this also assumes you have the song located in a location that OH can access.
Sure that is possible. You need to have an item linked to your plug, and write a rule that triggers to the event (changed to on or changed to off, changes in power consumption, etc) you want. As already stated above, you need a sound file and then you can use the play command as stated in the docs: https://www.openhab.org/docs/configuration/multimedia.html
Also search the forum, there are a lot of examples for playing a sound triggered by an event in OH2.
