Play Sound on Rule in OpenHAB 2
I want to play the “doorbell” sound by a self-defined rule (created with the Eclipse Smart Home IDE). I want to play the sound when an Item receives a command.
When I use the Rules Engine via the Paper UI everything works fine, see the screenshots of my rule:
Everytime I send a MQTT message to the specified topic, the sound is played in my browser tab with the OpenHAB UI opened.
However, I tried to “code” this rule also by the Eclipse Smart Home IDE, I used the following code:
rule "TestA"
when Item TestStringItem received command then
	playSound("doorbell.mp3")
This seems not to work, the “playSound” command is not known - I get the following error on the code: The method playSound(String) is undefined
How can I use the Audio functions in my rules code?
Hi Daniel
I am having the same problem. Did you find a solution?
I am trying to get playStream to work but I get the same error when I run playStream or playSound from a rule file.
Kind Regards
Craig
Post your code, please
Hi
Sorry, after staring at it for a while longer I figured it out. I copied the code from an example online and got the wrong type of quotes.
Incorrect command which doesn’t work:
playSound(“doorbell.mp3”)
Correct command which works:
Here my working rule:
rule "windowOpenCommand"
when Item Heizung_Bad_Fensterkontakt_FensterZustand changed to OPEN then
	isWindowOpen = true;
	while(isWindowOpen == true) {
		Thread::sleep(1000);
		secsWindowOpen = secsWindowOpen + 1;
		if(secsWindowOpen >= 600) {
			if(secsWindowOpen % 300 == 0) {
				playSound("RedAlert.mp3");
This plays a sound every 10 minutes, if the window is open…
Sound file has to be added to the sounds directory.
I can’t remember if I had to change something else… Let me know if it worked, if not, I will have a detailed look
Great to see that it worked also for you! :wink:
While this may be working, this rule bloks a thread for 10 minutes or more if the window stays opened. You only have 5 threads to play with in openhab. If you have 5 of the same rules and you windows are opened, openHAB will stop executing any other rules.
There is a diffrent approach with the expire binding.
  1. install the expire binding
  2. new item:
Switch windowTimer { expire="10m, command=OFF" }
  1. rules
    windowTimer.sendCommand(ON) // Start timer if window open
rule "windowClosedCommand"
    windowTimer.sendCommand(OFF) // Stop timer if window closed
rule "window timer"
    Item windowTimer received command OFF // Timer ended
    if (Heizung_Bad_Fensterkontakt_FensterZustand.state.toString == "OPEN") {
        windowTimer.sendCommand(ON) // reset timer
Good luck
gelöscht
