Strange things, OH2 stops responding and too many errors in log, can anybody translate to human language?
This happens when i try to view graphs, i connected from remote computer, OH2 UI very slow loading and stops responding.
OH2, MariaDB, mqtt is installed locally.
2017-02-06 09:25:29.907 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@b4488c' takes more than 5000ms.
2017-02-06 09:25:45.289 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10a388b' takes more than 5000ms.
2017-02-06 09:26:49.625 [WARN ] [.whistlingfish.harmony.HarmonyClient] - Send heartbeat failed
2017-02-06 09:26:50.016 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
2017-02-06 09:26:49.678 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@10a3e75' takes more than 5000ms.
2017-02-06 09:26:49.676 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@b4488c' takes more than 5000ms.
2017-02-06 09:26:49.640 [WARN ] [com.zaxxer.hikari.pool.HikariPool ] - 1m20s359ms25μs430ns - Thread starvation or clock leap detected (housekeeper delta=yank-default).
2017-02-06 09:26:50.846 [ERROR] [o.client.mqttv3.internal.ClientState] - openhab2: Timed out as no activity, keepAlive=60,000 lastOutboundActivity=1,486,362,410,069 lastInboundActivity=1,486,362,348,100
2017-02-06 09:26:52.076 [ERROR] [g.mqtt.internal.MqttMessagePublisher] - Error publishing...
Client is not connected (32104)
017-02-06 09:26:52.099 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
Timed out waiting for a response from the server (32000)
2017-02-06 09:27:27.220 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'oh2agdisk' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
2017-02-06 09:27:27.227 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'oh2agdisk'
2017-02-06 09:27:37.232 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'oh2agdisk'
2017-02-06 10:17:02.298 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-02-06 10:17:06.114 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-02-06 10:17:06.163 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-02-06 10:21:49.855 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLTransientConnectionException: yank-default - Connection is not available, request timed out after 38010ms.
2017-02-06 10:27:59.798 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /chart
java.lang.OutOfMemoryError: Java heap space
