- Platform information:
- Hardware: Raspberry Pi 3b+
- OS: openhabian_v1.6-755(0290f04)
- Java Runtime Environment: openjdk version “1.8.0_252”
- openHAB version: 2.5.6-2
- Issue: OpenHAB unpredictably, but seemingly on a more regular basis is crashing such that I cannot access the sitemap using the iphone app or any browser. Occasionally the rules are still firing in the background but eventually they grind to a halt as well. Access to the console also ceases. The info below suggests Java heap space issue. I have searched the forums and while there is a lot of information I am feeling a bit out of my depth in diagnosing this. One of the suggestions was to set up the ability to generate a hprof file when openhab (the jvm?) crashed. I did that and the output is listed below, but I’m not sure what to make of it or if it is even relevant.
I have a number of bindings including Astro, Australian Bureau of Meteorology (from Marketplace), Expire, HTTP, iCloud, Kodi, Log Reader, Network, NTP, Onkyo, OpenSprinkler, Samsung TV, Serial, TCP/UDP, System Info, Wake on LAN, Zwave. I have node-red, grafana and influxdb installed via openhabian menu options. I have the influxdb, mapdb and 44d4j persistence services installed.
I haven’t offloaded the logs and am not using zram. Not sure what other information may be relevant, but I am happy to provide it.
I know that I can increase the heap space allocated but rather than take a scattergun approach and hope something works, I thought I might try a more informed approach. Also I read that increasing the heap space is likely to delay the issue rather than fix the problem. It has also been suggested to remove then add bindings in slowly to see where memory is being used, however I am not sure how to actually track that. I tried to install Visual VM but that was a bit over my head.
Any help in working out what is going on is greatly appreciated.
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-08-01 23:27:52 AEST; 23h ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 558 (java)
Tasks: 205 (limit: 2319)
Memory: 440.9M
CGroup: /system.slice/openhab2.service
└─558 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2
Aug 02 22:13:49 openhab karaf[558]: Exception in thread "Active Thread: Equinox Container: a099b0d0-8329-4576-8f55-1a038d4bbfae" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:13:52 openhab karaf[558]: Exception in thread "OH-OSGiEventManager" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:13:55 openhab karaf[558]: Exception in thread "OkHttp Dispatcher" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:13:55 openhab karaf[558]: Exception in thread "JmDNS(JmDNS-/192.168.1.3).Timer" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:14:00 openhab karaf[558]: Exception in thread "OH-discovery-2355" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:14:03 openhab karaf[558]: Exception in thread "pool-12-thread-1" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:14:03 openhab karaf[558]: Exception in thread "OH-common-1598" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:14:10 openhab karaf[558]: Exception in thread "OkHttp Dispatcher" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:15:17 openhab karaf[558]: Exception in thread "OH-discovery-2361" java.lang.OutOfMemoryError: Java heap space
Aug 02 22:36:40 openhab karaf[558]: Exception in thread "OkHttp Dispatcher" java.lang.OutOfMemoryError: Java heap space
Eclipse Memory Analyzer tool output:
this log was generated during the crash prior to the status message posted above (about 24 hours earlier) - sadly I didn’t think to keep a copy of the status message at that time and strangely when openhab crashed this evening, a new hprof wasn’t generated (not sure if I needed to delete the old one, but i have done so now in anticipation of another crash.
12,226 instances of "org.quartz.simpl.TriggerWrapper", loaded by "org.openhab.core.scheduler" occupy 116,927,904 (47.94%) bytes. These instances are referenced from one instance of "java.lang.Object[]", loaded by "<system class loader>"
Keywords
java.lang.Object[]
Common Path To the Accumulation Point
Class Name Ref. Objects Shallow Heap Ref. Shallow Heap Retained Heap
org.quartz.core.QuartzSchedulerThread @ 0x6ba666b8 openHAB-job-scheduler_QuartzSchedulerThread Thread 9,999 168 239,976 1,048
<Java Local> org.quartz.simpl.RAMJobStore @ 0x6baaab78 9,999 72 239,976 4,666,792
triggers java.util.ArrayList @ 0x6bab5b00 9,999 24 239,976 68,368
elementData java.lang.Object[17083] @ 0x68e7f8d0 9,999 68,344 239,976 68,344
[4832] org.quartz.simpl.TriggerWrapper @ 0x73c2fa40 1 24 24 9,568
[4834] org.quartz.simpl.TriggerWrapper @ 0x73c2fa70 1 24 24 9,568
[4835] org.quartz.simpl.TriggerWrapper @ 0x73c2fa88 1 24 24 9,568
[8987] org.quartz.simpl.TriggerWrapper @ 0x67693d08 1 24 24 9,568
[6909] org.quartz.simpl.TriggerWrapper @ 0x661e31c0 1 24 24 9,568
[4838] org.quartz.simpl.TriggerWrapper @ 0x73c2fad0 1 24 24 9,568
[4839] org.quartz.simpl.TriggerWrapper @ 0x73c2fae8 1 24 24 9,568
[11065] org.quartz.simpl.TriggerWrapper @ 0x68b448e8 1 24 24 9,568
[4841] org.quartz.simpl.TriggerWrapper @ 0x73c2fb18 1 24 24 9,568
[4842] org.quartz.simpl.TriggerWrapper @ 0x73c2fb30 1 24 24 9,568
[4843] org.quartz.simpl.TriggerWrapper @ 0x73c2fb48 1 24 24 9,568
[4846] org.quartz.simpl.TriggerWrapper @ 0x73c2fb90 1 24 24 9,568
[10091] org.quartz.simpl.TriggerWrapper @ 0x68191d18 1 24 24 9,568
[11604] org.quartz.simpl.TriggerWrapper @ 0x690b9388 1 24 24 9,568
[6000] org.quartz.simpl.TriggerWrapper @ 0x65895e70 1 24 24 9,568
[8013] org.quartz.simpl.TriggerWrapper @ 0x66ce11e8 1 24 24 9,568
[6974] org.quartz.simpl.TriggerWrapper @ 0x66288c88 1 24 24 9,568
[12088] org.quartz.simpl.TriggerWrapper @ 0x695b6b68 1 24 24 9,568
[11584] org.quartz.simpl.TriggerWrapper @ 0x69081990 1 24 24 9,568
[6065] org.quartz.simpl.TriggerWrapper @ 0x6593b948 1 24 24 9,568
[10156] org.quartz.simpl.TriggerWrapper @ 0x68237830 1 24 24 9,568
[8078] org.quartz.simpl.TriggerWrapper @ 0x66d86d10 1 24 24 9,568
[7039] org.quartz.simpl.TriggerWrapper @ 0x6632e760 1 24 24 9,568
[5061] org.quartz.simpl.TriggerWrapper @ 0x742f5178 1 24 24 9,568
[9117] org.quartz.simpl.TriggerWrapper @ 0x677df368 1 24 24 9,568
Total: 25 of 9,999 entries; 9,974 more 9,999 239,976 239,976
org.quartz.simpl.SimpleThreadPool$WorkerThread @ 0x6ba67390 openHAB-job-scheduler_Worker-3 Thread
1 144 24 20,056
<Java Local> org.quartz.simpl.TriggerWrapper @ 0x70e3bcd0
1 24 24 9,568
Total: 2 entries
10,000 312 240,000
