So… The lock works almost as expected. It does not update openhab when manually locked or unlocked. Looking into it shows that I need to some coding with the Alarm_raw. This also means that I need to use a transform.
I have been following the wright up, but do not fully under stand:
I have used PaperUI to install JSONPATH and MAP Transformation. I am confused by what the: MAP (lock.map) is and what I need to do to create it.
I have create an Item that looks like this
Group:Switch:OR(OFF,ON) gLock "Locks [MAP(lock.map):%s]" <lock>
Group gLockRaw "Locks (raw) [%s]" <lock>
Switch Z_Wave_Front_Door_Lock "Lock (Front Entrance) [MAP(lock.map):%s]" <lock> (gLock) {channel="zwave:device:Zstick:node6:lock_door"}
String Z_Wave_Front_Door_Lock_Alarm_Raw "Lock (Front Entrance): Alarm Raw [%s]" <shield> (gLockRaw) {channel="zwave:device:Zstick:node6:alarm_raw"}
The wright up also talks about an import org.eclipse.smarthome.model.script.ScriptServiceUtil being at the top the rules. Does this mean the to of all the rules or the top of my lock rules? What is this import, why do I need it and how do I get it?
Also I have a list of alrarm_raw events, but I do not know where to place them.
And always, any help or advise is appreciated.
