Hi All,
Im trying to get this widget to work for my gate.
I have 2 switches and 1 contact. The contact monitors the gate state, open or closed.
The two switches are used to open/close, one opens/closes the gate fully. The other opens it partially.
Im trying to get the buttons to show green when triggered/open, and grey when closed. But it fails to work
Can someone please help me? Ive tried ALOT of things but given I have no experience with coding Iâm totally lost.
<div class="section">
<div class="sectionIconContainer"><div class="sectionIcon"><svg viewBox="0 0 48 48"><use xlink:href="/static/matrix-theme/squidink.svg#window"></use></svg></div></div>
<div class="title">Gate</div>
<div class="controls"></div>
<div class="widget" ng-if="itemValue('GateFullyProxy')=='ON'" ng-click="sendCmd('GateFullyProxy', 'OFF')">
<div class="icon off" ><svg viewBox="0 0 48 48"><use xlink:href="/static/matrix-theme/matrixicons.svg#off"></use></svg></div>
<div class="name">Open/Close {{itemValue('GateFullyProxy')}}</div>
</div>
<div class="widget" ng-if="itemValue('GateFullyProxy')=='OFF'" ng-click="sendCmd('GateFullyProxy', 'ON')">
<div class="icon on" ><svg viewBox="0 0 48 48"><use xlink:href="/static/matrix-theme/matrixicons.svg#on"></use></svg></div>
</div>
I have a map that translate ON to OPEN, OFF to CLOSED.
Thank you
pmpkk
(Patrick)
July 4, 2018, 9:35am
4
Whatâs the behavior you see? Is it a problem of states not being correct in OH or display only?
Hi patrick, thanks for the reply. I dont actually know what Iâm doing thats the issue
Basically the buttons work, they trigger correctly but the visual behaviour does not like it does when using Light switches.
Ie; they dont turn green when the Contact displays âOPEN or ONâ
Cheers
pmpkk
(Patrick)
July 4, 2018, 9:44am
6
Can you post the item config and any rules you have associated to those items?
Certainly
/* Gate & Garage Items*/
Switch GateFullyProxy "Fully" <door> { autoupdate="false" }
Switch GatePartialProxy "Partial" <door> { autoupdate="false" }
Switch GateFully "Fully" <door> { mqtt=">[broker:cmnd/gate/POWER1:command:*:default], <broker:stat/gate/POWER1:state:default]", autoupdate="false" }
Switch GatePartial "Partial" <door> { mqtt=">[broker:cmnd/gate/POWER2:command:*:default], <broker:stat/gate/POWER2:state:default]", autoupdate="false" }
Contact Gate "Gate Status" <door> { mqtt="<[broker:cmnd/gate_switch/POWER4:state:MAP(door.map)]" }
rule "GateFullyProxy"
Item GateFullyProxy received command
GateFully.sendCommand(receivedCommand)
rule "GatePartialProxy"
Item GatePartialProxy received command
GatePartial.sendCommand(receivedCommand)
rule "Gate changed"
Item Gate changed
val gateState = Gate.state
if (gateState == OPEN) {
GateFullyProxy.postUpdate(ON)
GatePartialProxy.postUpdate(ON)
} else {
GateFullyProxy.postUpdate(OFF)
GatePartialProxy.postUpdate(OFF)
pmpkk
(Patrick)
July 4, 2018, 9:49am
8
In your template code, I think your icons are switched around.
When the state is âOFFâ you want to display â#off â.
Same form on. Right now itâs the other way.
Also the CSS class is switched around.
I tried that also. i tried the combinations, but perhaps I got it wrong
Is this the modification you suggest?
<div class="widget" ng-if="itemValue('GateFullyProxy')=='ON'" ng-click="sendCmd('GateFullyProxy', 'ON')">
</div>
<div class="widget" ng-if="itemValue('GateFullyProxy')=='OFF'" ng-click="sendCmd('GateFullyProxy', 'OFF')">
</div>
pmpkk
(Patrick)
July 4, 2018, 9:55am
10
Correct. Whatâs the bahavior now? Can you post two screenshots?
EdiT: no, itâs still wrong 1 sec
pmpkk
(Patrick)
July 4, 2018, 9:59am
12
</div>
</div>
pmpkk:
<div class=âwidgetâ ng-if=âitemValue(âGateFullyProxyâ)==âONââ ng-click=âsendCmd(âGateFullyProxyâ, âOFFâ)â> <div class=âicon onâ ><svg viewBox=â0 0 48 48â><use xlink:href=â/static/matrix-theme/matrixicons.svg#onâ></use></svg></div> <div class=ânameâ>Open/Close {{itemValue(âGateFullyProxyâ)}}</div> </div> <div class=âwidgetâ ng-if=âitemValue(âGateFullyProxyâ)==âOFFââ ng-click=âsendCmd(âGateFullyProxyâ, âONâ)â> <div class=âicon offâ ><svg viewBox=â0 0 48 48â><use xlink:href=â/static/matrix-theme/matrixicons.svg#offâ></use></svg></div> <div class=ânameâ>Open/Close {{itemValue(âGateFullyProxyâ)}}</div> </div>
Thanks , unforunately the gate doesnt open
OK, odd behaviour
It opens from closed. And it lights up in HabPanel as being OPEN but it cant close it when its open. It wont respond to the clicks/close. Perhaps the state is causing it grief?
using Basic UI i can open/close fine
pmpkk
(Patrick)
July 4, 2018, 10:11am
15
Sorry, I donât understand what the states mean.
Really this a tri-state?
Open
Closed
Partially open
Wouldnât it better to mange this like a rollershutter, then?
Its a garage motor which has 2 relays, one to open partially and one to open fully.
And closed.
Iâm not entirely sure Patrick Iâm really really new to this⊠You may be right.
pmpkk
(Patrick)
July 4, 2018, 10:16am
17
I see. I have awnings (on the terrace) that I display like this:
This allows me to know the state (open, close, partial) and set the state (open, close, partial). For the awning, I can be very specific (and give any percentage of partial). So for you, youâd just need one extra state.
Maybe something like this:
Make sense?
Hi Patrick
Absolutely!!!
Yes, that would work just fine I think. Can you share what Iâd need to make that work?
Thank you! no rush Thanks for replying, this has been bugging me for a week!
PS: Your matrix theme is fantastic!! Great work
