I’ve been using the Plex binding. It was working a while ago and then I didn’t use it for a while, and then it broke. The Openhab log shows:
2015-09-28 11:14:17.345 [ERROR] [.b.plex.internal.PlexConnector] - Error while sending command to Plex: Bad Request
Bad Request
400 Bad Request
I finally figured that if I revert to Plex Media Server version 9.12.1, the binding works again. (Reverting just involves downloading the old version and running it. Old versions are here: Media Server Downloads | Plex Media Server for Windows, Mac, Linux, FreeBSD and More) I see that HTTPS was implemented from version 9.12.3, and that’s when the binding stopped working.
Is there an easy fix to get the binding working with HTTPS?
If anyone could point me in the right direction to solve this, it would be much appreciated. I can’t run a downgraded version of Plex server because the iOS app stops working if I do. I have seen the same issue here: Redirecting to Google Groups
and here: Plex mit OpenHab steuern - KNX-User-Forum
So it does seem to be affecting a number of people. I have also checked for any settings to try and disable https in plex server, but without any luck.
