Plex Binding - "Unable to fetch API, token may be wrong?"
Hey Folks,
I’ve got a test instance of OH 4.1.2 up and running and am experimenting with the Plex binding for the first time.
I generated a token for authentication and have validated my token is correct via a curl command (token and personal details randomised in snippet below):
curl -X GET "https://plex.tv/api/v2/user" \
  -H "Accept: application/json" \
  -H "X-Plex-Token: abctoken1234567890123""
{"id":00003140,"uuid":"61f1b7cc2a81ab49","username":"<user>","title":"<user>","email":"my@email","friendlyName":"","locale":null,"confirmed":true,"joinedAt":1585272761,"emailOnlyAuth":false,"hasPassword":true,"protected":false,"thumb":"https://plex.tv/users/61f1b7cc2a81ab49/avatar?c=1717026117","authToken":"abctoken1234567890123","mailingListStatus":"active","mailingListActive":true,"scrobbleTypes":"","country":"AU","subscription":.......
All looks good so far - except that I get this when setting up a server Thing:
CONFIGURATION_ERROR
I turned on tracing for the Plex binding (side note: thanks to whoever added this easy switching of log levels to the UI, I love it!)
The output is here (again, token and external IP obliterated):
2024-05-30 09:42:53.488 [DEBUG] [x.internal.handler.PlexServerHandler] - Initializing server handler
2024-05-30 09:42:53.537 [DEBUG] [x.internal.handler.PlexServerHandler] - Fetch API with config, org.openhab.binding.plex.internal.config.PlexServerConfiguration@4d6244c5
2024-05-30 09:42:53.920 [DEBUG] [ex.internal.handler.PlexApiConnector] - HTTP response: <?xml version="1.0" encoding="UTF-8"?>
<MediaContainer size="2">
  <Device name="hgnas" product="Plex Media Server" productVersion="1.29.2.6364-6d72b0cf6" platform="Linux" platformVersion="DSM 7.0.1.42218-0" device="DS220+" clientIdentifier="9edee779d49229d7b63dc2cf90802180fd882a1c" createdAt="1646272314" lastSeenAt="1716944225" provides="server" owned="1" accessToken="abctoken1234567890123" publicAddress="255.128.255.128" httpsRequired="0" synced="0" relay="1" dnsRebindingProtection="0" natLoopbackSupported="0" publicAddressMatches="1" presence="1">
    <Connection protocol="https" address="10.0.4.12" port="32400" uri="https://10-0-4-12.9a386df0878c49a0b352b5b774791689.plex.direct:32400" local="1"/>
    <Connection protocol="https" address="255.128.255.128" port="14644" uri="https://255-128-255-128.9a386df0878c49a0b352b5b774791689.plex.direct:14644" local="0"/>
  </Device>
  <Device name="TV 2023" product="Plex for Samsung" productVersion="5.82.2" platform="Tizen" platformVersion="7" device="23_NIKEL_UHD" clientIdentifier="da4nw6kkctizttsyu09n9el9" createdAt="1695962991" lastSeenAt="1716970985" provides="client,player" owned="1" publicAddress="255.128.255.128" publicAddressMatches="1" presence="0" accessToken="abctoken1234567890123">
  </Device>
</MediaContainer>
2024-05-30 09:42:53.925 [DEBUG] [ex.internal.handler.PlexApiConnector] - MediaContainer 2
Again, looks fine - it correctly identifies the Plex server and one of the players. I take from that that the token is validating fine.
My guess is that there might be an item in my Plex config that’s resulting in unexpected / incomplete data being sent back to the binding, and from there the Thing fails to initialise.
I’ve checked the binding config and the community here - happy to be pointed to something I’ve missed, equally happy to try any new tips!
Cheers,
Matt
