Hi all,
I have a problem getting the plex plugin up and running.
I configured everything as described within the manual and during startup I also get these information:
2017-07-27 20:43:37.403 [DEBUG] [ab.binding.plex.internal.PlexBinding] - Plex config, server at 10.10.10.2:32400
2017-07-27 20:43:37.810 [DEBUG] [.binding.plex.internal.PlexConnector] - Server found, version 1.7.5.4035-313f93718, api level v2
2017-07-27 20:43:38.073 [DEBUG] [.binding.plex.internal.PlexConnector] - Connecting web socket to Plex
2017-07-27 20:43:38.073 [INFO ] [b.core.service.AbstractActiveService] - Plex Refresh Service has been started
2017-07-27 20:43:38.086 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVPower bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property power
2017-07-27 20:43:38.114 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVStatus bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property state
2017-07-27 20:43:38.117 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVTitle bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property title
2017-07-27 20:43:38.118 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVType bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property type
2017-07-27 20:43:38.134 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVCover bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/cover
2017-07-27 20:43:38.137 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVProgress bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/progress
2017-07-27 20:43:38.139 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVEndTime bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/endTime
2017-07-27 20:43:38.139 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVVolume bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/volume
2017-07-27 20:43:38.140 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVPause bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/pause
2017-07-27 20:43:38.140 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVPlay bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/play
2017-07-27 20:43:38.141 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVPlayPause bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/playpause
2017-07-27 20:43:38.141 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVStop bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/stop
2017-07-27 20:43:38.142 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVSelect bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/select
2017-07-27 20:43:38.142 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVBack bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/back
2017-07-27 20:43:38.142 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVUp bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/moveUp
2017-07-27 20:43:38.143 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVDown bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/moveDown
2017-07-27 20:43:38.143 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVLeft bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/moveLeft
2017-07-27 20:43:38.143 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVRight bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property navigation/moveRight
2017-07-27 20:43:38.144 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVForward bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/stepForward
2017-07-27 20:43:38.144 [INFO ] [.internal.PlexGenericBindingProvider] - Plex item PlexTVReverse bound to client 1964F2E6-E361-4D91-B82A-70FAE6BB5228 property playback/stepBack
2017-07-27 20:43:44.800 [INFO ] [e.smarthome.model.script.-----> Rule] - livingroom_tab executed tab state:2017-07-27T18:43:45::state:34
The versioin which is mentioned above (1.7.5.4035-313f93718) is correct, thus the plugin is somehow connected to the server. But unfortionatly if I switch an arbitary item I get the following error message:
2017-07-27 20:39:24.958 [DEBUG] [.binding.plex.internal.PlexConnector] - 10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct
java.net.UnknownHostException: 10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)[:1.8.0_131]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_131]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)[:1.8.0_131]
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)[:1.8.0_131]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)[:1.8.0_131]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)[:1.8.0_131]
at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)[:1.8.0_131]
at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)[:1.8.0_131]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)[:1.8.0_131]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)[:1.8.0_131]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)[:1.8.0_131]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)[:1.8.0_131]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)[:1.8.0_131]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)[:1.8.0_131]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)[:1.8.0_131]
at org.openhab.binding.plex.internal.PlexConnector.doHttpRequest(PlexConnector.java:617)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.getDocument(PlexConnector.java:594)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.getHost(PlexConnector.java:414)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.sendCommand(PlexConnector.java:238)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexBinding.internalReceiveCommand(PlexBinding.java:147)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:97)[185:org.openhab.core.compat1x:2.1.0]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:45)[185:org.openhab.core.compat1x:2.1.0]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[6:org.apache.karaf.services.eventadmin:4.0.8]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[6:org.apache.karaf.services.eventadmin:4.0.8]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_131]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
2017-07-27 20:39:24.958 [DEBUG] [.binding.plex.internal.PlexConnector] - [10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct]: Websocket connection error
2017-07-27 20:39:24.959 [DEBUG] [.binding.plex.internal.PlexConnector] - Error connecting to Plex
java.util.concurrent.ExecutionException: java.net.ConnectException: wss://10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct:32400/:/websockets/notifications?X-Plex-Token=SECRET_TOKEN
at com.ning.http.client.providers.netty.NettyResponseFuture.abort(NettyResponseFuture.java:341)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.providers.netty.NettyConnectListener.operationComplete(NettyConnectListener.java:107)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.channel.DefaultChannelFuture.notifyListener(DefaultChannelFuture.java:427)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.channel.DefaultChannelFuture.addListener(DefaultChannelFuture.java:145)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.doConnect(NettyAsyncHttpProvider.java:1130)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.execute(NettyAsyncHttpProvider.java:927)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.AsyncHttpClient.executeRequest(AsyncHttpClient.java:524)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.AsyncHttpClient$BoundRequestBuilder.execute(AsyncHttpClient.java:236)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.open(PlexConnector.java:198)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.connect(PlexConnector.java:479)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexConnector.run(PlexConnector.java:186)[188:org.openhab.binding.plex:1.10.0]
Caused by: java.net.ConnectException: wss://10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct:32400/:/websockets/notifications?X-Plex-Token=SECRET_TOKEN
at com.ning.http.client.providers.netty.NettyConnectListener.operationComplete(NettyConnectListener.java:103)[188:org.openhab.binding.plex:1.10.0]
... 9 more
Caused by: java.nio.channels.UnresolvedAddressException
at sun.nio.ch.Net.checkAddress(Net.java:101)[:1.8.0_131]
at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:622)[:1.8.0_131]
at org.jboss.netty.channel.socket.nio.NioClientSocketPipelineSink.connect(NioClientSocketPipelineSink.java:108)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.channel.socket.nio.NioClientSocketPipelineSink.eventSunk(NioClientSocketPipelineSink.java:70)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.handler.ssl.SslHandler.handleDownstream(SslHandler.java:608)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.handler.codec.oneone.OneToOneEncoder.handleDownstream(OneToOneEncoder.java:54)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.handler.codec.http.HttpClientCodec.handleDownstream(HttpClientCodec.java:97)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.channel.Channels.connect(Channels.java:634)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.channel.AbstractChannel.connect(AbstractChannel.java:207)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.bootstrap.ClientBootstrap.connect(ClientBootstrap.java:229)[188:org.openhab.binding.plex:1.10.0]
at org.jboss.netty.bootstrap.ClientBootstrap.connect(ClientBootstrap.java:182)[188:org.openhab.binding.plex:1.10.0]
at com.ning.http.client.providers.netty.NettyAsyncHttpProvider.doConnect(NettyAsyncHttpProvider.java:1091)[188:org.openhab.binding.plex:1.10.0]
... 6 more
at org.openhab.binding.plex.internal.PlexConnector.refresh(PlexConnector.java:587)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.binding.plex.internal.PlexBinding.execute(PlexBinding.java:61)[188:org.openhab.binding.plex:1.10.0]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:157)[185:org.openhab.core.compat1x:2.1.0]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169)[185:org.openhab.core.compat1x:2.1.0]
2017-07-27 20:39:24.959 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVPlayPause] {bridgemarker=true, item=PlexTVPlayPause, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, token=SECRET_TOKEN, username=Jakez666, service.pid=org.openhab.plex, component.id=180, password=linux666, event.topics=openhab/command/*, host=10.10.10.2, service.id=304, service.bundleid=188, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.10.0 [188])]
java.lang.NullPointerException
at org.openhab.binding.plex.internal.PlexConnector.getHost(PlexConnector.java:417)[188:org.openhab.binding.plex:1.10.0]
2017-07-27 20:39:28.576 [DEBUG] [.binding.plex.internal.PlexConnector] - 10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct
2017-07-27 20:39:28.577 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/PlexTVStop] {bridgemarker=true, item=PlexTVStop, command=ON} | {org.osgi.service.event.EventHandler}={component.name=org.openhab.binding.plex.binding, port=32400, token=SECRET_TOKEN, username=Jakez666, service.pid=org.openhab.plex, component.id=180, password=linux666, event.topics=openhab/command/*, host=10.10.10.2, service.id=304, service.bundleid=188, service.scope=bundle} | Bundle(org.openhab.binding.plex_1.10.0 [188])]
2017-07-27 20:39:29.965 [DEBUG] [.binding.plex.internal.PlexConnector] - [10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct]: Websocket connection error
2017-07-27 20:39:29.965 [DEBUG] [.binding.plex.internal.PlexConnector] - Error connecting to Plex
... 9 more
... 6 more
2017-07-27 20:39:29.968 [DEBUG] [.binding.plex.internal.PlexConnector] - 10-10-10-2.68946a0204cc41cb85215b3339621180.plex.direct
Any ideas how to debug/proceed here?
Cheers
Dennis
