Thing plugwise:circle:KK_Koelkast "Koelkast" (plugwise:stick:000D6F00004EF02F) [ macAddress="000D6F00004B9EBC", powerStateChanging="alwaysOn" ] {
Channels:
Type power : power [ updateInterval=10 ]
When I add a location I get the error:
2018-04-07 21:10:04.121 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model âplugwise.thingsâ has errors, therefore ignoring it: [41,57]: missing EOF at â(â
When I try to add a location in the Paper UI I get this error:
2018-04-07 21:14:20.134 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for update at âthings/plugwise:circle:KK_Koelkastâ for an unmanaged thing âplugwise:circle:KK_Koelkastâ.
Iâm new to zigbee and plugwise, so maybe this has been asked before. Iâm tempting to buy a zone heating system based on plugwise. With the Lisa, Thom and Adam devices. Are they supported? I think not because i canât find it anywhee. If not, would it be possible to add support for those devices?
Currently the Plugwise binding only supports what they call nowadays the âPlugwise HNSâ system (see Dutch, English).
Perhaps the Plugwise Lisa, Tom, Adam devices can be used with the more generic Zigbee Binding?
On the Plugwise website they write for these products that:
The Plugwise Home automation products communicate via the open Zigbee standard âHome Automation 1.2â
I havenât tested this myself though. Maybe you can ask Plugwise support if these devices can be used in a Zigbee mesh with other non-Plugwise devices.
Itâs currently only possible to use devices that have been added with the Source software. If we know the messages/protocol for adding/removing devices itâs possible to also add it to the binding. But it may also result in new issues. E.g. when devices (Things) are added/removed in openHAB they would also be added/removed from the node list on the Stick. These devices will probably not be automatically added/removed in the Source database.
