I have the Supported and controlled Z-wave command classes at a manual paper that came together with the unit, so I might be able to add it to the database myself - if someone gives me instructions how to do it.
This is the beta version from a few months back so it won’t include this device - you should change to use the latest snapshot of the complete runtime which you can get here -:
Hm, do I need to remove and add the new thing again, since it was added with the old version of openhab2 - or does openhab2 search the new database. I can see the thing is listed on the about screen of the Z-Wave binding - so it should be there.
010101 Popp Wireless Thermostatic Valve TRV
zwave:danfoss_010101_00_000
Inclusion Information
Short push middle button
Yes - just delete the thing, and add it back again - there’s no need to actually exclude the device from the network and add it back. Doing this will update the thing configuration from the latest XML.
Because that’s how the device identifies itself. It’s made by Danfoss (as is the Danfoss, and Devolo devices that look the same), not Popp.
It does not seem to store any xml for that node in /var/lib/openhab2/zwave/ - however it stores for the other items - am i looking in the wrong folder?
If it’s not generating an XML, then either there’s a problem, or, you’ve not woken the device up - it’s a battery device, so it does need manual intervention…
