No, there is nog âYellow LEDâ on the unit, only a red LED. It blinks to indicate error situaties (possibly also battery alarm, I will pay attention to that). Also, there is beep when the battery is low.
As reported by @Celeano1 in a different post, the beeps are more frequently when the battery is lower.
Notes to the original log : (see below)
- My smoke detector was beeping for at least a few days
- Then, I have put new batteries in at approx 18:30 or so**!
- AFTER THAT, the first battery alarm came at 18:35:52.550 for my smokedector node5
- The battery alarm seems to come twice.
- There is also a smoke alarm coming, as a third message
Here the original log:
2022-12-22 18:35:52.541 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 80 03 FF 88
2022-12-22 18:35:52.543 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 80 03 FF
2022-12-22 18:35:52.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 80 03 FF
2022-12-22 18:35:52.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-22 18:35:52.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:SUC_ROUTE)
2022-12-22 18:35:52.548 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2022-12-22 18:35:52.549 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_BATTERY
2022-12-22 18:35:52.550 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2022-12-22 18:35:52.551 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 5: Battery report value = 255
2022-12-22 18:35:52.553 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 5: BATTERY LOW!
2022-12-22 18:35:52.554 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-12-22 18:35:52.555 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=0
2022-12-22 18:35:52.556 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:0748817ea2:node5:battery-level to 0 [DecimalType]
2022-12-22 18:35:52.558 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-12-22 18:35:52.560 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@c6779c.
2022-12-22 18:35:52.561 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-22 18:35:52.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-22 18:35:52.579 [INFO ] [openhab.core.model.script.Rule CM-ST] - đĽ Smokedetector First floor empty!
2022-12-22 18:35:52.761 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 80 03 FF 88
2022-12-22 18:35:52.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 80 03 FF
2022-12-22 18:35:52.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 80 03 FF
2022-12-22 18:35:52.766 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-22 18:35:52.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:SUC_ROUTE)
2022-12-22 18:35:52.768 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2022-12-22 18:35:52.769 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_BATTERY
2022-12-22 18:35:52.770 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2022-12-22 18:35:52.771 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 5: Battery report value = 255
2022-12-22 18:35:52.772 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 5: BATTERY LOW!
2022-12-22 18:35:52.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-12-22 18:35:52.775 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=0
2022-12-22 18:35:52.776 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:0748817ea2:node5:battery-level to 0 [DecimalType]
2022-12-22 18:35:52.777 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-12-22 18:35:52.778 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bd04f9.
2022-12-22 18:35:52.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-22 18:35:52.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-22 18:35:52.796 [INFO ] [openhab.core.model.script.Rule CM-ST] - đĽ Smokedetector First floor empty!
2022-12-22 18:35:52.828 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 04 05 0B 71 05 00 00 00 FF 01 02 00 00 00 68
2022-12-22 18:35:52.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=4, payload=04 05 0B 71 05 00 00 00 FF 01 02 00 00 00
2022-12-22 18:35:52.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=4, payload=04 05 0B 71 05 00 00 00 FF 01 02 00 00 00
2022-12-22 18:35:52.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-22 18:35:52.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:SUC_ROUTE)
2022-12-22 18:35:52.834 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2022-12-22 18:35:52.835 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_ALARM
2022-12-22 18:35:52.836 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2022-12-22 18:35:52.837 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=2, status=255, plen=0
2022-12-22 18:35:52.838 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = SMOKE (0)
2022-12-22 18:35:52.838 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2022-12-22 18:35:52.839 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2022-12-22 18:35:52.840 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter processing NOTIFICATION
2022-12-22 18:35:52.841 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 2, type OnOffType
2022-12-22 18:35:52.842 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 5: Alarm converter NOTIFICATION event is 2, channel alarm_general is not implemented.
2022-12-22 18:35:52.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-12-22 18:35:52.844 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 17 03 25 03 FF 3F
2022-12-22 18:35:52.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f3b94a.
2022-12-22 18:35:52.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.846 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=23, callback=0, payload=00 17 03 25 03 FF
2022-12-22 18:35:52.846 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-22 18:35:52.849 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=23, callback=0, payload=00 17 03 25 03 FF
2022-12-22 18:35:52.850 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
