I recently ran into a problem that broke my 2.4.0 build #1381 OH system. I have an RFXCOM device and there was interference in the neighborhood on the 433MHz wireless channel. This led to constant new devices appearing in PaperUI Inbox, and /var/lib/openhab2/jsondb/backup creating several files per minute until the system ran out of disk space. I’m running on an SSD with plenty of life remaining, so I doubt its corruption.
I fixed it by turning off discovery in the RFXCOM binding and deleting the files.
Normally there are 5 backup files which is the setting I have set, so perhaps during stress periods the old file deletion stops working, and this is a bug?
Whilst this interference was present I couldn’t unlock my car with the keyfob unless I was right against its door when it sometimes worked, and I could hear the continuous signal on an RF scanner.
To summarise, excessive discovery activity causes /var/lib/openhab2/jsondb/backup to grow until disk is full
