Hi @tarag, unfortunately I see that your great enhancement (taphold) does not get the traction it deserves probably also because it is hidden in the label card advanced config menu.
I think this is really great as it is a more intuitive way to open a context screen/menu instead of trying to hit the three dots in the upper right corner of cells.
I have some questions:
I see that taphold is just available for oh-label-card and oh-button. Will there be a support for cells or are they aleady there and I cannot find it?
Is it possible to expand a card by taphold, i.e. show the default slot of a card/cell?
Yeah. Sorry if it sounds dumb, but, it is just a “tap the screen” to pop up a sub menu? Or must we keep the finger in the screen…? I’m not quite following…
no problem. yes, you tap&hold the card for about 1 second and can release the button. then the popup appears. It is the same result as you would have defined it via action: popup
The release of your finger is irrelevant. Even if you tap&hold for 3 seconds, the popup already appears after 1 second.
