otbe
(Benjamin)
October 7, 2016, 9:34pm
#1
Hi there,
Im not sure if this is a openhab2, openhab issue or no issue at all, but Im encountering a strange behavior. Sometimes I use the postUpdate method to “fake” some values in the timeline of an Item. So for example:
myItem.sendCommand(18);
myItem.postUpdate(16);
myItem.postUpdate(4);
logInfo('Whats the previous value of myItem? ', myItem.previousState().state); // logs 18
I use postUpdate to not trigger any binding action. Is this expected behavior or am I doing something wrong?
Facts:
I use some of the latest snapshot builds of openhab2 on a RPI2 with mysql as persistent backend.
mysql.persist:
Items {
* : strategy = everyChange, everyUpdate
Thanks!
Kai
(Kai Kreuzer)
October 8, 2016, 8:07am
#2
You have a typo in
myItem.postUpate(4);
Nonetheless, I would expect it to log “16” in this case.
Do you have any logs from the persistence service?
otbe
(Benjamin)
October 8, 2016, 8:27am
#3
Fixed typo.
There is no output from the persistence service. Event log says myItem changed from 18 to 16 and from 16 to 4. Thats it
Should I enable debug mode for the mysql service?
Btw: 16 is also my expected result
Kai
(Kai Kreuzer)
October 8, 2016, 8:38am
#4
Yes, this should tell you what values are persisted by the persistence layer.
otbe
(Benjamin)
October 8, 2016, 9:07am
#5
Mh thats very strange. If I do:
I get:
2016-10-08 10:53:27.060 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'myItem' as '18'[18] in SQL database at 2016-10-08 10:53:27.061.
2016-10-08 10:53:27.061 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item252 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
2016-10-08 10:53:27.157 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'myItem' as '16'[16] in SQL database at 2016-10-08 10:53:27.149.
2016-10-08 10:53:27.160 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item252 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
2016-10-08 10:53:27.169 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'myItem' as '4'[4] in SQL database at 2016-10-08 10:53:27.167.
2016-10-08 10:53:27.172 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item252 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
2016-10-08 10:53:27.181 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'myItem' as '4'[4] in SQL database at 2016-10-08 10:53:27.178.
2016-10-08 10:53:27.182 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item252 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
2016-10-08 10:53:27.191 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'myItem' as '4'[4] in SQL database at 2016-10-08 10:53:27.188.
2016-10-08 10:53:27.193 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item252 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;
Why 4 is inserted three times?
But nonetheless it should log 16 as myItem.previousState(true).state
and not 18!?
