Thank your for your hint.
The package list shows no duplicate entries for org.apache.cxf.* packages. These are all bound to org.apache.cxf bundles. The javax.ws.* packages are bound to org.apache.aries.javax.jax.rs-api bundles. This is independent from the installation of the conflicting TR-064 binding.
In a slightly different set-up (removing all other bindings, disabling retry connection for the Sony binding), I’m observing an endless loop of registering/installation and unregistering/uninstallation sequence of components or services (see below log), and the UI becomes unresponsive.
This looks to me as if the binding of runtime dependencies for different components/services (ui, Sony and TR-064 binding) are in conflict to each other, and that the runtime unsuccessfully tries to resolve this conflict (through the FeaturesServiceImpl?). But I have no idea on how to further analyse or even fix this conflict.
So any further hint would be highly appreciated.
2024-10-03 13:17:24.608 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
2024-10-03 13:17:24.620 [WARN ] [org.apache.felix.fileinstall ] - \usr\share\openhab\addons does not exist, please create it.
2024-10-03 13:17:24.621 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: C:\usr\share\openhab\addons
2024-10-03 13:17:25.379 [INFO ] [raf.deployer.features.osgi.Activator] - Deployment finished. Registering FeatureDeploymentListener
2024-10-03 13:17:26.098 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:26.101 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:26.103 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:26.117 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.commands/4.4.6
2024-10-03 13:17:26.118 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.shell.commands/4.4.6
2024-10-03 13:17:26.119 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.deployer.kar/4.4.6
2024-10-03 13:17:26.348 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.wrapper.core/4.4.6
2024-10-03 13:17:26.376 [INFO ] [ROOT ] - bundle org.apache.felix.scr:2.2.6 (74) Starting with globalExtender setting: false
2024-10-03 13:17:26.385 [INFO ] [ROOT ] - bundle org.apache.felix.scr:2.2.6 (74) Version = 2.2.6
2024-10-03 13:17:26.437 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.bundle.core/4.4.6
2024-10-03 13:17:26.454 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.config.command/4.4.6
2024-10-03 13:17:26.666 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.diagnostic.core/4.4.6
2024-10-03 13:17:26.688 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.features.command/4.4.6
2024-10-03 13:17:26.711 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.instance.core/4.4.6
2024-10-03 13:17:26.727 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.kar.core/4.4.6
2024-10-03 13:17:26.740 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.log.core/4.4.6
2024-10-03 13:17:26.755 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.package.core/4.4.6
2024-10-03 13:17:26.819 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.service.core/4.4.6
2024-10-03 13:17:26.851 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.shell.ssh/4.4.6. Missing service: [org.apache.sshd.server.SshServer]
2024-10-03 13:17:26.861 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.system.core/4.4.6
2024-10-03 13:17:26.886 [INFO ] [tender.whiteboard.internal.Activator] - Starting Pax Web Whiteboard Extender
2024-10-03 13:17:26.941 [INFO ] [org.eclipse.jetty.util.log ] - Logging initialized @4021ms to org.eclipse.jetty.util.log.Slf4jLog
2024-10-03 13:17:26.970 [INFO ] [j.pax.web.service.internal.Activator] - Scheduling Pax Web reconfiguration because configuration has changed
2024-10-03 13:17:26.970 [INFO ] [j.pax.web.service.internal.Activator] - EventAdmin support enabled, WAB events will be posted to EventAdmin topics.
2024-10-03 13:17:26.971 [INFO ] [j.pax.web.service.internal.Activator] - Pax Web Runtime started
2024-10-03 13:17:26.971 [INFO ] [j.pax.web.service.internal.Activator] - Scheduling Pax Web reconfiguration because ServerControllerFactory has been registered
2024-10-03 13:17:27.034 [INFO ] [j.pax.web.service.internal.Activator] - Configuring server controller org.ops4j.pax.web.service.jetty.internal.JettyServerController
2024-10-03 13:17:27.035 [INFO ] [jetty.internal.JettyServerController] - Configuring JettyServerController{configuration=98120565-6851-4896-ad99-d41cd5fa3e09,state=UNCONFIGURED}
2024-10-03 13:17:27.035 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Creating Jetty server instance using configuration properties.
2024-10-03 13:17:27.059 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-frontend-jaxrs (69) [org.apache.cxf.jaxrs.JAXRSBindingFactory]
2024-10-03 13:17:27.062 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-rs-sse (71) [org.apache.cxf.transport.sse.SseProvidersExtension]
2024-10-03 13:17:27.063 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-transports-http (73) [org.apache.cxf.transport.http.HTTPTransportFactory, org.apache.cxf.transport.http.HTTPWSDLExtensionLoader, org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder, org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder, org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider]
2024-10-03 13:17:27.066 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Processing Jetty configuration from files: [C:\Users\Andreas\develop\openHAB\runtimes\OPENHA~1.0\runtime\etc\jetty.xml]
2024-10-03 13:17:27.114 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:27.117 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:27.172 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:27.191 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered RuntimeDelegate
2024-10-03 13:17:27.194 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered ClientBuilder
2024-10-03 13:17:27.196 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered SseEventSourceFactory
2024-10-03 13:17:27.197 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered SseEventSource.Builder
2024-10-03 13:17:27.337 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.ssh/4.4.6
2024-10-03 13:17:27.347 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Found configured connector "0.0.0.0:8443": 0.0.0.0:8443
2024-10-03 13:17:27.349 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Creating non secure connector for address 0.0.0.0:8080
2024-10-03 13:17:27.351 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.stax.WstxEventFactory of service javax.xml.stream.XMLEventFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.352 [INFO ] [.service.jetty.internal.JettyFactory] - HTTP/2 ClearText support available, adding "h2c" protocol support to default connector
2024-10-03 13:17:27.353 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.stax.WstxInputFactory of service javax.xml.stream.XMLInputFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.357 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.dtd.DTDSchemaFactory of service org.codehaus.stax2.validation.XMLValidationSchemaFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.361 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.msv.RelaxNGSchemaFactory of service org.codehaus.stax2.validation.XMLValidationSchemaFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.363 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.msv.W3CSchemaFactory of service org.codehaus.stax2.validation.XMLValidationSchemaFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.365 [INFO ] [.service.jetty.internal.JettyFactory] - Default Jetty connector created: default@687bf803{HTTP/1.1, (http/1.1, h2c)}{0.0.0.0:8080}
2024-10-03 13:17:27.366 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Using configured 0.0.0.0:8443@4663a3cc{SSL, (ssl, http/1.1)}{0.0.0.0:8443} as secure connector for address: 0.0.0.0:8443
2024-10-03 13:17:27.366 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.ctc.wstx.stax.WstxOutputFactory of service javax.xml.stream.XMLOutputFactory in bundle com.fasterxml.woodstox.woodstox-core
2024-10-03 13:17:27.367 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Eagerly starting Jetty thread pool QueuedThreadPool[qtp2083000951]@7c281277{STOPPED,2<=0<=50,i=0,r=-1,q=0}[NO_TRY]
2024-10-03 13:17:27.371 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider de.focus_shift.jollyday.jackson.JacksonConfigurationService of service de.focus_shift.jollyday.core.spi.ConfigurationService in bundle de.focus_shift.jollyday-jackson
2024-10-03 13:17:27.375 [INFO ] [.service.jetty.internal.JettyFactory] - Adding JMX support to Jetty server
2024-10-03 13:17:27.379 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.alpn.java.client.JDK9ClientALPNProcessor of service org.eclipse.jetty.io.ssl.ALPNProcessor$Client in bundle org.eclipse.jetty.alpn.java.client
2024-10-03 13:17:27.381 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.alpn.java.server.JDK9ServerALPNProcessor of service org.eclipse.jetty.io.ssl.ALPNProcessor$Server in bundle org.eclipse.jetty.alpn.java.server
2024-10-03 13:17:27.384 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.http.Http1FieldPreEncoder of service org.eclipse.jetty.http.HttpFieldPreEncoder in bundle org.eclipse.jetty.http
2024-10-03 13:17:27.385 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.http2.hpack.HpackFieldPreEncoder of service org.eclipse.jetty.http.HttpFieldPreEncoder in bundle org.eclipse.jetty.http2.hpack
2024-10-03 13:17:27.388 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.security.openid.OpenIdAuthenticatorFactory of service org.eclipse.jetty.security.Authenticator$Factory in bundle org.eclipse.jetty.openid
2024-10-03 13:17:27.394 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.identity.IdentityExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2024-10-03 13:17:27.396 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.fragment.FragmentExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2024-10-03 13:17:27.398 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.PerMessageDeflateExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2024-10-03 13:17:27.400 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.DeflateFrameExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2024-10-03 13:17:27.402 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.XWebkitDeflateFrameExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2024-10-03 13:17:27.406 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.jsr356.JettyClientContainerProvider of service javax.websocket.ContainerProvider in bundle org.eclipse.jetty.websocket.javax.websocket
2024-10-03 13:17:27.409 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.jsr356.server.ContainerDefaultConfigurator of service javax.websocket.server.ServerEndpointConfig$Configurator in bundle org.eclipse.jetty.websocket.javax.websocket.server
2024-10-03 13:17:27.411 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.jsr356.server.deploy.WebSocketServerContainerInitializer of service javax.servlet.ServletContainerInitializer in bundle org.eclipse.jetty.websocket.javax.websocket.server
2024-10-03 13:17:27.414 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.server.NativeWebSocketServletContainerInitializer of service javax.servlet.ServletContainerInitializer in bundle org.eclipse.jetty.websocket.server
2024-10-03 13:17:27.424 [INFO ] [j.pax.web.service.internal.Activator] - Starting server controller org.ops4j.pax.web.service.jetty.internal.JettyServerController
2024-10-03 13:17:27.425 [INFO ] [jetty.internal.JettyServerController] - Starting JettyServerController{configuration=98120565-6851-4896-ad99-d41cd5fa3e09,state=STOPPED}
2024-10-03 13:17:27.425 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Starting Server@7fc4e698{STOPPED}[9.4.54.v20240208]
2024-10-03 13:17:27.427 [INFO ] [org.eclipse.jetty.server.Server ] - jetty-9.4.54.v20240208; built: 2024-02-08T19:42:39.027Z; git: cef3fbd6d736a21e7d541a5db490381d95a2047d; jvm 17.0.2+8-86
2024-10-03 13:17:27.451 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.event/4.4.6
2024-10-03 13:17:27.503 [INFO ] [org.eclipse.jetty.server.session ] - DefaultSessionIdManager workerName=node0
2024-10-03 13:17:27.504 [INFO ] [org.eclipse.jetty.server.session ] - No SessionScavenger set, using defaults
2024-10-03 13:17:27.506 [INFO ] [org.eclipse.jetty.server.session ] - node0 Scavenging every 600000ms
2024-10-03 13:17:27.514 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.e.j.s.h.ContextHandler@294ca83e{/static,null,AVAILABLE}
2024-10-03 13:17:27.579 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.2.0 (Release Build)
2024-10-03 13:17:27.587 [INFO ] [pse.jetty.util.ssl.SslContextFactory] - x509=X509@7172f4c(mykey,h=[openhab.org],a=[],w=[]) for Server@11550020[provider=null,keyStore=file:///C:/Users/Andreas/develop/openHAB/runtimes/openhab-4.2.0/userdata/etc/keystore,trustStore=file:///C:/Users/Andreas/develop/openHAB/runtimes/openhab-4.2.0/userdata/etc/keystore]
2024-10-03 13:17:27.690 [INFO ] [lipse.jetty.server.AbstractConnector] - Started 0.0.0.0:8443@4663a3cc{SSL, (ssl, http/1.1)}{0.0.0.0:8443}
2024-10-03 13:17:27.701 [INFO ] [lipse.jetty.server.AbstractConnector] - Started default@687bf803{HTTP/1.1, (http/1.1, h2c)}{0.0.0.0:8080}
2024-10-03 13:17:27.702 [INFO ] [org.eclipse.jetty.server.Server ] - Started @4793ms
2024-10-03 13:17:27.704 [INFO ] [j.pax.web.service.internal.Activator] - Registering HttpService factory
2024-10-03 13:17:27.707 [INFO ] [j.pax.web.service.internal.Activator] - Registering HttpServiceRuntime
2024-10-03 13:17:27.708 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.ops4j.pax.web.pax-web-extender-whiteboard_8.0.27 [230]]
2024-10-03 13:17:27.708 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - created whiteboard from configuration: {felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, replace.loopback.address.with.localhost=false, service.pid=org.apache.aries.jax.rs.whiteboard.default}
2024-10-03 13:17:27.926 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2024-10-03 13:17:27.932 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '50.278500626238596,8.794555664062502'.
2024-10-03 13:17:27.932 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_DE'.
2024-10-03 13:17:28.030 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.apache.aries.jax.rs.whiteboard_2.0.2 [65]]
2024-10-03 13:17:28.032 [INFO ] [internal.BundleWhiteboardApplication] - No matching target context(s) for Whiteboard element ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[]}. Filter: (osgi.http.whiteboard.context.name=default). Element may be re-registered later, when matching context/s is/are registered.
2024-10-03 13:17:28.051 [INFO ] [ax.web.service.spi.model.ServerModel] - Created new ServletContextModel{id=ServletContextModel-4,contextPath='/'}
2024-10-03 13:17:28.052 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}", size=2}
2024-10-03 13:17:28.053 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Creating new Jetty context for ServletContextModel{id=ServletContextModel-4,contextPath='/'}
2024-10-03 13:17:28.119 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,STOPPED}
2024-10-03 13:17:28.124 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Changing default OSGi context model for o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,STOPPED}
2024-10-03 13:17:28.133 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:28.134 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:28.135 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:28.142 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Starting Jetty context "/" with default Osgi Context OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}
2024-10-03 13:17:28.160 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:28.160 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Registering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}} as OSGi service for "/" context path
2024-10-03 13:17:28.579 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
2024-10-03 13:17:28.732 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.audio_4.2.0 [160]]
2024-10-03 13:17:28.739 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-6,name='/audio',urlPatterns=[/audio/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:28.748 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-6,name='/audio',urlPatterns=[/audio/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:28.749 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-6,name='/audio',urlPatterns=[/audio/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.242 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.openhab.core.io.console.karaf/4.2.0
2024-10-03 13:17:29.268 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.io.http_4.2.0 [178]]
2024-10-03 13:17:29.271 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of OsgiContextModel{WB,id=OCM-7,name='default',path='/',bundle=org.openhab.core.io.http,ref={org.osgi.service.http.HttpContext, org.openhab.core.io.http.WrappingHttpContext}={service.id=282, osgi.http.whiteboard.context.name=oh-dfl-http-ctx, service.bundleid=178, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.http.internal.OpenHABHttpContext, osgi.http.whiteboard.context.path=/, component.id=150}}", size=1}
2024-10-03 13:17:29.272 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{WB,id=OCM-7,name='default',path='/',bundle=org.openhab.core.io.http,ref={org.osgi.service.http.HttpContext, org.openhab.core.io.http.WrappingHttpContext}={service.id=282, osgi.http.whiteboard.context.name=oh-dfl-http-ctx, service.bundleid=178, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.http.internal.OpenHABHttpContext, osgi.http.whiteboard.context.path=/, component.id=150}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:29.293 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.io.http.auth_4.2.0 [179]]
2024-10-03 13:17:29.295 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-9,name='/auth',urlPatterns=[/auth/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.296 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-9,name='/auth',urlPatterns=[/auth/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:29.297 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-9,name='/auth',urlPatterns=[/auth/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.299 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-10,name='/changePassword',urlPatterns=[/changePassword/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.300 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-10,name='/changePassword',urlPatterns=[/changePassword/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:29.301 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-10,name='/changePassword',urlPatterns=[/changePassword/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.303 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-11,name='/createApiToken',urlPatterns=[/createApiToken/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.305 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-11,name='/createApiToken',urlPatterns=[/createApiToken/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:29.306 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-11,name='/createApiToken',urlPatterns=[/createApiToken/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:29.362 [INFO ] [ax.web.service.spi.model.ServerModel] - Created new ServletContextModel{id=ServletContextModel-14,contextPath='/rest'}
2024-10-03 13:17:29.363 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}", size=2}
2024-10-03 13:17:29.365 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Creating new Jetty context for ServletContextModel{id=ServletContextModel-14,contextPath='/rest'}
2024-10-03 13:17:29.367 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@e6cd0d3{/rest,null,STOPPED}
2024-10-03 13:17:29.369 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Changing default OSGi context model for o.o.p.w.s.j.i.PaxWebServletContextHandler@e6cd0d3{/rest,null,STOPPED}
2024-10-03 13:17:29.370 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}
2024-10-03 13:17:29.371 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}", size=1}
2024-10-03 13:17:29.373 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}
2024-10-03 13:17:29.374 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Starting Jetty context "/rest" with default Osgi Context OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}
2024-10-03 13:17:29.376 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.o.p.w.s.j.i.PaxWebServletContextHandler@e6cd0d3{/rest,null,AVAILABLE}
2024-10-03 13:17:29.377 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Registering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}} as OSGi service for "/rest" context path
2024-10-03 13:17:29.539 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.643 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.728 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.747 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.800 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.823 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.854 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.878 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.900 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.933 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.959 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:29.989 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.034 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.079 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.118 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.181 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.226 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.304 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.371 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:30.551 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 172.18.240.1
2024-10-03 13:17:30.916 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.io.websocket_4.2.0 [195]]
2024-10-03 13:17:30.919 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:30.920 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:30.921 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:30.974 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:31.017 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:31.021 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:32.335 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2024-10-03 13:17:32.687 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2024-10-03 13:17:32.689 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2024-10-03 13:17:32.690 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to install:
2024-10-03 13:17:32.691 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.eclipse.jetty.http2/http2-hpack/9.4.54.v20240208
2024-10-03 13:17:32.694 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2024-10-03 13:17:32.696 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.voice/4.2.0
2024-10-03 13:17:32.701 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.ui/4.2.0
2024-10-03 13:17:32.702 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.transform/4.2.0
2024-10-03 13:17:32.704 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.sitemap/4.2.0
2024-10-03 13:17:32.706 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-transports-http/3.6.2
2024-10-03 13:17:32.708 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-security/3.6.2
2024-10-03 13:17:32.710 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-sse/3.6.2
2024-10-03 13:17:32.711 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-client/3.6.2
2024-10-03 13:17:32.713 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-frontend-jaxrs/3.6.2
2024-10-03 13:17:32.714 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-core/3.6.2
2024-10-03 13:17:32.722 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:32.725 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:32.727 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-3,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:32.738 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}"
2024-10-03 13:17:32.739 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}]", size=1}
2024-10-03 13:17:32.740 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-15,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-12,context.foropenhab,/rest}]}
2024-10-03 13:17:32.743 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}", size=1}
2024-10-03 13:17:32.744 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}} from o.o.p.w.s.j.i.PaxWebServletContextHandler@e6cd0d3{/rest,null,AVAILABLE}
2024-10-03 13:17:32.746 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Unegistering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-12,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=298, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=163, original.service.id=297, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}} as OSGi service for "/rest" context path
2024-10-03 13:17:32.747 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Stopping Jetty context "/rest"
2024-10-03 13:17:32.749 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped o.o.p.w.s.j.i.PaxWebServletContextHandler@e6cd0d3{/rest,null,STOPPED}
2024-10-03 13:17:32.750 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - destroyed whiteboard from configuration: {felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, replace.loopback.address.with.localhost=false, service.pid=org.apache.aries.jax.rs.whiteboard.default}
2024-10-03 13:17:32.752 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered SseEventSource.Builder
2024-10-03 13:17:32.753 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered SseEventSourceFactory
2024-10-03 13:17:32.754 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered ClientBuilder
2024-10-03 13:17:32.756 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered RuntimeDelegate
2024-10-03 13:17:32.759 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 69
2024-10-03 13:17:32.760 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 71
2024-10-03 13:17:32.761 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 73
2024-10-03 13:17:32.762 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.swagger/4.2.0
2024-10-03 13:17:32.764 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.audio/4.2.0
2024-10-03 13:17:32.766 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.id/4.2.0
2024-10-03 13:17:32.767 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/4.2.0
2024-10-03 13:17:32.771 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.aries.jax.rs.whiteboard/2.0.2
2024-10-03 13:17:32.772 [INFO ] [internal.StoppableHttpServiceFactory] - Unbinding HTTP Service from bundle: [org.apache.aries.jax.rs.whiteboard_2.0.2 [65]]
2024-10-03 13:17:32.776 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Stopping HttpService (enabled) for bundle org.apache.aries.jax.rs.whiteboard_2.0.2 [65]", size=0}
2024-10-03 13:17:32.776 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.karaf/4.2.0
2024-10-03 13:17:32.779 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:32.781 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:32.784 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.websocket/4.2.0
2024-10-03 13:17:32.785 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:32.786 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:32.788 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-17,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:32.792 [INFO ] [internal.StoppableHttpServiceFactory] - Unbinding HTTP Service from bundle: [org.openhab.core.io.websocket_4.2.0 [195]]
2024-10-03 13:17:32.793 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Stopping HttpService (enabled) for bundle org.openhab.core.io.websocket_4.2.0 [195]", size=0}
2024-10-03 13:17:32.794 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.sse/4.2.0
2024-10-03 13:17:32.796 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.core/4.2.0
2024-10-03 13:17:32.801 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest/4.2.0
2024-10-03 13:17:32.804 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.auth/4.2.0
2024-10-03 13:17:32.807 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.servicemix.bundles.saaj-impl/1.4.0.2
2024-10-03 13:17:32.812 [INFO ] [internal.service.FeaturesServiceImpl] - Installing bundles:
2024-10-03 13:17:32.813 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.eclipse.jetty.http2/http2-hpack/9.4.54.v20240208
2024-10-03 13:17:32.820 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2024-10-03 13:17:32.821 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.aries.jax.rs.whiteboard/2.0.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.822 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-core/3.6.2 (Wired to org.apache.servicemix.bundles.saaj-impl/1.4.0.2 which is being refreshed)
2024-10-03 13:17:32.823 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-frontend-jaxrs/3.6.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.824 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-client/3.6.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.825 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-sse/3.6.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.826 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-security/3.6.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.827 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-transports-http/3.6.2 (Wired to org.apache.cxf.cxf-core/3.6.2 which is being refreshed)
2024-10-03 13:17:32.828 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.servicemix.bundles.saaj-impl/1.4.0.2 (Should be wired to: org.jvnet.staxex.stax-ex/1.7.4 (through [org.apache.servicemix.bundles.saaj-impl/1.4.0.2] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.jvnet.staxex)(version>=1.7.0)(!(version>=2.0.0)))"))
2024-10-03 13:17:32.828 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/4.2.0 (Wired to org.apache.aries.jax.rs.whiteboard/2.0.2 which is being refreshed)
2024-10-03 13:17:32.829 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.id/4.2.0 (Wired to org.apache.aries.jax.rs.whiteboard/2.0.2 which is being refreshed)
2024-10-03 13:17:32.830 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest/4.2.0 (Wired to org.apache.aries.jax.rs.whiteboard/2.0.2 which is being refreshed)
2024-10-03 13:17:32.830 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.audio/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.831 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.auth/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.832 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.core/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.832 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.sitemap/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.833 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.sse/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.834 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.swagger/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.835 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.transform/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.835 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.ui/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.836 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.voice/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.837 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.websocket/4.2.0 (Wired to org.openhab.core.io.rest.auth/4.2.0 which is being refreshed)
2024-10-03 13:17:32.839 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.karaf/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.840 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.ui.icon/4.2.0 (Wired to org.openhab.core.io.rest/4.2.0 which is being refreshed)
2024-10-03 13:17:32.841 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.ui.basic/4.2.0 (Wired to org.openhab.core.io.rest.sitemap/4.2.0 which is being refreshed)
2024-10-03 13:17:32.842 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.ui.iconset.classic/4.2.0 (Wired to org.openhab.core.ui.icon/4.2.0 which is being refreshed)
2024-10-03 13:17:33.049 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-frontend-jaxrs (69) [org.apache.cxf.jaxrs.JAXRSBindingFactory]
2024-10-03 13:17:33.051 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-rs-sse (71) [org.apache.cxf.transport.sse.SseProvidersExtension]
2024-10-03 13:17:33.052 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Adding the extensions from bundle org.apache.cxf.cxf-rt-transports-http (73) [org.apache.cxf.transport.http.HTTPTransportFactory, org.apache.cxf.transport.http.HTTPWSDLExtensionLoader, org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder, org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder, org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider]
2024-10-03 13:17:33.088 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:33.092 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:33.098 [INFO ] [blueprint.NamespaceHandlerRegisterer] - Aries Blueprint packages not available. So namespaces will not be registered
2024-10-03 13:17:33.118 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered RuntimeDelegate
2024-10-03 13:17:33.119 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered ClientBuilder
2024-10-03 13:17:33.121 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered SseEventSourceFactory
2024-10-03 13:17:33.122 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Registered SseEventSource.Builder
2024-10-03 13:17:33.157 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - created whiteboard from configuration: {felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, replace.loopback.address.with.localhost=false, service.pid=org.apache.aries.jax.rs.whiteboard.default}
2024-10-03 13:17:33.236 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.apache.aries.jax.rs.whiteboard_2.0.2 [65]]
2024-10-03 13:17:33.237 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:33.239 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:33.240 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:33.272 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}", size=1}
2024-10-03 13:17:33.273 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Creating new Jetty context for ServletContextModel{id=ServletContextModel-23,contextPath='/rest'}
2024-10-03 13:17:33.275 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@1b5dfaaf{/rest,null,STOPPED}
2024-10-03 13:17:33.277 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Changing default OSGi context model for o.o.p.w.s.j.i.PaxWebServletContextHandler@1b5dfaaf{/rest,null,STOPPED}
2024-10-03 13:17:33.278 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}
2024-10-03 13:17:33.279 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}", size=1}
2024-10-03 13:17:33.280 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}
2024-10-03 13:17:33.281 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Starting Jetty context "/rest" with default Osgi Context OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}
2024-10-03 13:17:33.283 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.o.p.w.s.j.i.PaxWebServletContextHandler@1b5dfaaf{/rest,null,AVAILABLE}
2024-10-03 13:17:33.284 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Registering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}} as OSGi service for "/rest" context path
2024-10-03 13:17:33.367 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.427 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.461 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.474 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.504 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.523 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.541 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.559 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.575 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.594 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.613 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.640 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.667 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.702 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.738 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.778 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.822 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.879 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.941 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:33.987 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.io.websocket_4.2.0 [195]]
2024-10-03 13:17:33.990 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-25,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:33.991 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-25,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:33.992 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-25,name='/ws',urlPatterns=[/ws/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.037 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:34.077 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:34.080 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.4.6
2024-10-03 13:17:34.092 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.ui.icon_4.2.0 [224]]
2024-10-03 13:17:34.094 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-26,name='/icon',urlPatterns=[/icon/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.095 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-26,name='/icon',urlPatterns=[/icon/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:34.096 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-26,name='/icon',urlPatterns=[/icon/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.113 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:34.165 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.ui.basic_4.2.0 [271]]
2024-10-03 13:17:34.167 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.168 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:34.169 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.171 [INFO ] [.service.internal.HttpServiceEnabled] - Registering resources with [/basicui/*] mapping(s) and resource base "web"
2024-10-03 13:17:34.174 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.176 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:34.177 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:34.178 [INFO ] [internal.service.FeaturesServiceImpl] - Starting bundles:
2024-10-03 13:17:34.181 [INFO ] [ty.internal.web.JettyResourceServlet] - Initialized Jetty Resource Servlet for base="web" with cache maxSize=4096kB, maxEntrySize=2048kB, maxEntries=2048
2024-10-03 13:17:34.187 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.voice/4.2.0
2024-10-03 13:17:34.233 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:34.276 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.transform/4.2.0
2024-10-03 13:17:34.321 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:34.360 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.jupnp/4.2.0
2024-10-03 13:17:34.365 [INFO ] [internal.service.FeaturesServiceImpl] - org.jupnp/3.0.1
2024-10-03 13:17:34.377 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.upnp/4.2.0
2024-10-03 13:17:34.392 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.config.jupnp_4.2.0 [264]]
2024-10-03 13:17:34.553 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-29,name='org.jupnp.transport.impl.async.AsyncServlet',alias='/upnpcallback',urlPatterns=[/upnpcallback/*],servlet=org.jupnp.transport.impl.async.AsyncServlet@6ac3e018,contexts=[{HS,OCM-30,context:2102264190,/}]}
2024-10-03 13:17:34.554 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-29,name='org.jupnp.transport.impl.async.AsyncServlet',alias='/upnpcallback',urlPatterns=[/upnpcallback/*],servlet=org.jupnp.transport.impl.async.AsyncServlet@6ac3e018,contexts=null}", size=3}
2024-10-03 13:17:34.555 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{HS,id=OCM-30,name='context:2102264190',path='/',bundle=org.openhab.core.config.jupnp,context=WebContainerContextWrapper{bundle=org.openhab.core.config.jupnp_4.2.0 [264],contextId='context:2102264190',delegate=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@7d4e017e}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:34.557 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Changing default OSGi context model for o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:34.558 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Unegistering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}} as OSGi service for "/" context path
2024-10-03 13:17:34.559 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Stopping Jetty context "/"
2024-10-03 13:17:34.560 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,STOPPED}
2024-10-03 13:17:34.560 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Starting Jetty context "/" with default Osgi Context OsgiContextModel{HS,id=OCM-30,name='context:2102264190',path='/',bundle=org.openhab.core.config.jupnp,context=WebContainerContextWrapper{bundle=org.openhab.core.config.jupnp_4.2.0 [264],contextId='context:2102264190',delegate=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@7d4e017e}}
2024-10-03 13:17:34.564 [INFO ] [ty.internal.web.JettyResourceServlet] - Initialized Jetty Resource Servlet for base="web" with cache maxSize=4096kB, maxEntrySize=2048kB, maxEntries=2048
2024-10-03 13:17:34.565 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:34.566 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Registering OsgiServletContext{model=OsgiContextModel{HS,id=OCM-30,name='context:2102264190',path='/',bundle=org.openhab.core.config.jupnp,context=WebContainerContextWrapper{bundle=org.openhab.core.config.jupnp_4.2.0 [264],contextId='context:2102264190',delegate=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@7d4e017e}}} as OSGi service for "/" context path
2024-10-03 13:17:34.568 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-29,name='org.jupnp.transport.impl.async.AsyncServlet',alias='/upnpcallback',urlPatterns=[/upnpcallback/*],servlet=org.jupnp.transport.impl.async.AsyncServlet@6ac3e018,contexts=[{HS,OCM-30,context:2102264190,/}]}
2024-10-03 13:17:34.612 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.sony/4.0.0.202409291557
2024-10-03 13:17:34.628 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.thing/4.2.0
2024-10-03 13:17:35.568 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2024-10-03 13:17:35.782 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:35.847 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:35.905 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:35.991 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:36.585 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:36.637 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.usbserial.linuxsysfs/4.2.0
2024-10-03 13:17:36.643 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.usbserial.ser2net/4.2.0
2024-10-03 13:17:36.647 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.usbserial/4.2.0
2024-10-03 13:17:36.665 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.usbserial.windowsregistry/4.2.0
2024-10-03 13:17:36.672 [INFO ] [internal.service.FeaturesServiceImpl] - nrjavaserial/5.2.1.OH1
2024-10-03 13:17:36.674 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/4.2.0
2024-10-03 13:17:36.678 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/4.2.0
2024-10-03 13:17:36.682 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/4.2.0
2024-10-03 13:17:36.706 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/4.2.0
2024-10-03 13:17:36.713 [INFO ] [internal.service.FeaturesServiceImpl] - org.threeten.extra/1.8.0
2024-10-03 13:17:36.716 [INFO ] [internal.service.FeaturesServiceImpl] - wrap_file__C__Users_Andreas_develop_openHAB_runtimes_openhab-4.2.0_userdata_tmp_kar_org.openhab.binding.sony-4.0.0_2_org_lastnpe_eea_eea-all_2.2.1_eea-all-2.2.1.jar/0.0.0
2024-10-03 13:17:36.718 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.persistence.rrd4j/4.2.0
2024-10-03 13:17:36.751 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.ui/4.2.0
2024-10-03 13:17:36.765 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.core.ui_4.2.0 [223]]
2024-10-03 13:17:36.767 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-33,name='/chart',urlPatterns=[/chart/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.767 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-33,name='/chart',urlPatterns=[/chart/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:36.768 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-33,name='/chart',urlPatterns=[/chart/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.839 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:36.908 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.909 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:36.910 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.911 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.912 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:36.913 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:36.923 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:36.924 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.persistence.rrd4j_4.2.0 [269]]
2024-10-03 13:17:36.943 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Initialization of HttpContext "default" for org.openhab.persistence.rrd4j_4.2.0 [269]", size=2}
2024-10-03 13:17:36.944 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{HS,id=OCM-36,name='default',path='/',bundle=org.openhab.persistence.rrd4j,context=DefaultHttpContext{bundle=org.openhab.persistence.rrd4j_4.2.0 [269],contextId='default'}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:36.947 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-38,name='org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet',alias='/rrdchart.png',urlPatterns=[/rrdchart.png/*],servlet=org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet@43229e2d,contexts=[{HS,OCM-36,default,/}]}
2024-10-03 13:17:36.948 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-38,name='org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet',alias='/rrdchart.png',urlPatterns=[/rrdchart.png/*],servlet=org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet@43229e2d,contexts=null}", size=1}
2024-10-03 13:17:36.949 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-38,name='org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet',alias='/rrdchart.png',urlPatterns=[/rrdchart.png/*],servlet=org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet@43229e2d,contexts=[{HS,OCM-36,default,/}]}
2024-10-03 13:17:36.970 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Initialization of HttpContext "default" for org.openhab.core.ui_4.2.0 [223]", size=2}
2024-10-03 13:17:36.975 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{HS,id=OCM-39,name='default',path='/',bundle=org.openhab.core.ui,context=DefaultHttpContext{bundle=org.openhab.core.ui_4.2.0 [223],contextId='default'}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:36.978 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-41,name='org.openhab.core.ui.internal.proxy.AsyncProxyServlet',alias='/proxy',urlPatterns=[/proxy/*],servlet=org.openhab.core.ui.internal.proxy.AsyncProxyServlet@361482f0,contexts=[{HS,OCM-39,default,/}]}
2024-10-03 13:17:36.979 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-41,name='org.openhab.core.ui.internal.proxy.AsyncProxyServlet',alias='/proxy',urlPatterns=[/proxy/*],servlet=org.openhab.core.ui.internal.proxy.AsyncProxyServlet@361482f0,contexts=null}", size=1}
2024-10-03 13:17:36.980 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-41,name='org.openhab.core.ui.internal.proxy.AsyncProxyServlet',alias='/proxy',urlPatterns=[/proxy/*],servlet=org.openhab.core.ui.internal.proxy.AsyncProxyServlet@361482f0,contexts=[{HS,OCM-39,default,/}]}
2024-10-03 13:17:37.021 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:37.055 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.sddp/4.2.0
2024-10-03 13:17:37.063 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.upnp/4.2.0
2024-10-03 13:17:37.070 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.addon.mdns/4.2.0
2024-10-03 13:17:37.083 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:37.094 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.addon.sddp/4.2.0
2024-10-03 13:17:37.104 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.addon.usb/4.2.0
2024-10-03 13:17:37.163 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:37.301 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:37.443 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server's publish address to be /
2024-10-03 13:17:37.515 [INFO ] [internal.StoppableHttpServiceFactory] - Binding HTTP Service for bundle: [org.openhab.ui_4.2.0 [226]]
2024-10-03 13:17:37.518 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Initialization of HttpContext "default" for org.openhab.ui_4.2.0 [226]", size=2}
2024-10-03 13:17:37.519 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{HS,id=OCM-42,name='default',path='/',bundle=org.openhab.ui,context=DefaultHttpContext{bundle=org.openhab.ui_4.2.0 [226],contextId='default'}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:37.523 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-44,name='/',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:37.525 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-44,name='/',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}", size=2}
2024-10-03 13:17:37.526 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:37.527 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-44,name='/',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:37.529 [INFO ] [.service.internal.HttpServiceEnabled] - Registering ServletModel{id=ServletModel-45,name='/error-447f0a9e-6712-481c-8909-d1f17cc3aede',urlPatterns=[/error-447f0a9e-6712-481c-8909-d1f17cc3aede],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:37.530 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of ServletModel{id=ServletModel-45,name='/error-447f0a9e-6712-481c-8909-d1f17cc3aede',urlPatterns=[/error-447f0a9e-6712-481c-8909-d1f17cc3aede],contexts=[{WB,OCM-1,default,/}]}", size=1}
2024-10-03 13:17:37.531 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding servlet ServletModel{id=ServletModel-45,name='/error-447f0a9e-6712-481c-8909-d1f17cc3aede',urlPatterns=[/error-447f0a9e-6712-481c-8909-d1f17cc3aede],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:37.532 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of OsgiContextModel{WB,id=OCM-47,name='org.openhab.ui.context',path='/',bundle=org.openhab.ui,ref={org.osgi.service.http.context.ServletContextHelper}={context.init.dirAllowed=false, service.id=594, service.bundleid=226, service.scope=bundle, context.init.redirectWelcome=false, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), context.init.preCompressed=true, component.name=org.openhab.ui.internal.UIContext, component.id=418, context.init.etags=true, context.init.acceptRanges=true, osgi.http.whiteboard.context.name=org.openhab.ui.context, osgi.http.whiteboard.context.path=/}}", size=1}
2024-10-03 13:17:37.534 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Adding OsgiContextModel{WB,id=OCM-47,name='org.openhab.ui.context',path='/',bundle=org.openhab.ui,ref={org.osgi.service.http.context.ServletContextHelper}={context.init.dirAllowed=false, service.id=594, service.bundleid=226, service.scope=bundle, context.init.redirectWelcome=false, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), context.init.preCompressed=true, component.name=org.openhab.ui.internal.UIContext, component.id=418, context.init.etags=true, context.init.acceptRanges=true, osgi.http.whiteboard.context.name=org.openhab.ui.context, osgi.http.whiteboard.context.path=/}} to o.o.p.w.s.j.i.PaxWebServletContextHandler@64d601d3{/,null,AVAILABLE}
2024-10-03 13:17:37.538 [INFO ] [.service.internal.HttpServiceEnabled] - Registering WelcomeFileModel{id=WelcomeFileModel-49,redirect='false',welcomeFiles=[index.html],contexts=[OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}]}
2024-10-03 13:17:37.543 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Registration of WelcomeFileModel{id=WelcomeFileModel-49,redirect='false',welcomeFiles=[index.html],contexts=[OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}]}", size=1}
2024-10-03 13:17:37.547 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Reconfiguration of welcome files for all resource servlets in context "OsgiContextModel{WB,id=OCM-1,name='default',path='/',bundle=org.ops4j.pax.web.pax-web-extender-whiteboard,context=(supplier)}"
2024-10-03 13:17:47.052 [WARN ] [re.internal.service.WatchServiceImpl] - Tried to add path '\etc\openhab\automation\lib\ruby\gem_home' to listener 'configWatcher', but the base path of this listener is 'C:\Users\Andreas\develop\openHAB\runtimes\OPENHA~1.0\conf'
2024-10-03 13:17:47.053 [WARN ] [re.internal.service.WatchServiceImpl] - Tried to add path '\etc\openhab\automation\lib\ruby\personal' to listener 'configWatcher', but the base path of this listener is 'C:\Users\Andreas\develop\openHAB\runtimes\OPENHA~1.0\conf'
2024-10-03 13:17:47.691 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.js.scriptengine.GraalJSEngineFactory of service javax.script.ScriptEngineFactory in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.694 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$ANDROID_AARCH64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.696 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$DARWIN_AARCH64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.698 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$DARWIN_AMD64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.700 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$IOS_AARCH64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.701 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$IOS_AMD64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.702 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$LINUX_AARCH64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.705 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$LINUX_AMD64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.706 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$WINDOWS_AARCH64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.707 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.nativeimage.Platform$WINDOWS_AMD64 of service org.graalvm.nativeimage.Platform in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.712 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.graalvm.home.impl.DefaultHomeFinder of service org.graalvm.home.HomeFinder in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.718 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.polyglot.PolyglotImpl of service org.graalvm.polyglot.impl.AbstractPolyglotImpl in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.720 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.object.DynamicObjectLibraryImplGen$DynamicObjectLibraryProvider of service com.oracle.truffle.api.library.DefaultExportProvider in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.726 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.js.parser.GraalJSEvaluator of service com.oracle.truffle.js.runtime.Evaluator in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.729 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.object.basic.DefaultLayoutFactory of service com.oracle.truffle.api.object.LayoutFactory in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.730 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.api.debug.impl.DebuggerInstrumentProvider of service com.oracle.truffle.api.instrumentation.TruffleInstrument$Provider in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.732 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.regex.RegexLanguageProvider of service com.oracle.truffle.api.TruffleLanguage$Provider in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:47.734 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider com.oracle.truffle.js.lang.JavaScriptLanguageProvider of service com.oracle.truffle.api.TruffleLanguage$Provider in bundle org.openhab.automation.jsscripting
2024-10-03 13:17:48.192 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@7a2316b8[provider=null,keyStore=null,trustStore=null]
2024-10-03 13:17:48.193 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@7a2316b8[provider=null,keyStore=null,trustStore=null]
2024-10-03 13:17:48.249 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-10-03 13:17:48.290 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script 'C:\Users\Andreas\develop\openHAB\runtimes\OPENHA~1.0\conf\automation\jsr223\ruby\personal\av_scene_new.rb'
2024-10-03 13:17:57.189 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.addon.upnp/4.2.0
2024-10-03 13:17:57.190 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.discovery.addon.ip/4.2.0
2024-10-03 13:17:57.191 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.automation.jrubyscripting/4.2.0
2024-10-03 13:17:57.191 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.automation.jsscripting/4.2.0
2024-10-03 13:17:57.191 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.ui/4.2.0
2024-10-03 13:17:57.192 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
2024-10-03 13:17:58.215 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2024-10-03 13:17:58.215 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2024-10-03 13:17:58.216 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to install:
2024-10-03 13:17:58.217 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.eclipse.jetty.http2/http2-hpack/9.4.54.v20240208
2024-10-03 13:17:58.217 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2024-10-03 13:17:58.218 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-security/3.6.2
2024-10-03 13:17:58.219 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-sse/3.6.2
2024-10-03 13:17:58.220 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-rs-client/3.6.2
2024-10-03 13:17:58.236 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-frontend-jaxrs/3.6.2
2024-10-03 13:17:58.238 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-core/3.6.2
2024-10-03 13:17:58.241 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:58.242 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-19,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:58.255 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}"
2024-10-03 13:17:58.256 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}]", size=1}
2024-10-03 13:17:58.256 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-22,name='cxf-servlet',urlPatterns=[/*],contexts=[{WB,OCM-20,context.foropenhab,/rest}]}
2024-10-03 13:17:58.257 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}", size=1}
2024-10-03 13:17:58.259 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}} from o.o.p.w.s.j.i.PaxWebServletContextHandler@1b5dfaaf{/rest,null,AVAILABLE}
2024-10-03 13:17:58.260 [INFO ] [rvice.spi.servlet.OsgiServletContext] - Unegistering OsgiServletContext{model=OsgiContextModel{WB,id=OCM-20,name='context.foropenhab',path='/rest',bundle=org.apache.aries.jax.rs.whiteboard,ref={org.osgi.service.http.context.ServletContextHelper}={original.service.bundleid=183, osgi.jaxrs.application.base=rest, replace.loopback.address.with.localhost=false, service.id=379, service.bundleid=65, service.scope=singleton, servlet.init.hide-service-list-page=true, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.io.rest.internal.RESTApplicationImpl, component.id=249, original.service.id=378, osgi.http.whiteboard.context.name=context.foropenhab, osgi.jaxrs.name=openhab, felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, osgi.http.whiteboard.target=(osgi.http.endpoint=*), service.pid=org.apache.aries.jax.rs.whiteboard.default, osgi.http.whiteboard.context.path=/rest}}} as OSGi service for "/rest" context path
2024-10-03 13:17:58.262 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Stopping Jetty context "/rest"
2024-10-03 13:17:58.263 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped o.o.p.w.s.j.i.PaxWebServletContextHandler@1b5dfaaf{/rest,null,STOPPED}
2024-10-03 13:17:58.266 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - destroyed whiteboard from configuration: {felix.fileinstall.filename=file:/var/lib/openhab/etc/org.apache.aries.jax.rs.whiteboard.default.cfg, replace.loopback.address.with.localhost=false, service.pid=org.apache.aries.jax.rs.whiteboard.default}
2024-10-03 13:17:58.268 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered SseEventSource.Builder
2024-10-03 13:17:58.268 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered SseEventSourceFactory
2024-10-03 13:17:58.297 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered ClientBuilder
2024-10-03 13:17:58.298 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered RuntimeDelegate
2024-10-03 13:17:58.299 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 69
2024-10-03 13:17:58.299 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 71
2024-10-03 13:17:58.299 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 73
2024-10-03 13:17:58.301 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.voice/4.2.0
2024-10-03 13:17:58.302 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.ui/4.2.0
2024-10-03 13:17:58.303 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.transform/4.2.0
2024-10-03 13:17:58.304 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.swagger/4.2.0
2024-10-03 13:17:58.306 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.rest.audio/4.2.0
2024-10-03 13:17:58.307 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.id/4.2.0
2024-10-03 13:17:58.308 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/4.2.0
2024-10-03 13:17:58.310 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.cxf.cxf-rt-transports-http/3.6.2
2024-10-03 13:17:58.312 [INFO ] [internal.service.FeaturesServiceImpl] - org.apache.aries.jax.rs.whiteboard/2.0.2
2024-10-03 13:17:58.313 [INFO ] [internal.StoppableHttpServiceFactory] - Unbinding HTTP Service from bundle: [org.apache.aries.jax.rs.whiteboard_2.0.2 [65]]
2024-10-03 13:17:58.314 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Stopping HttpService (enabled) for bundle org.apache.aries.jax.rs.whiteboard_2.0.2 [65]", size=0}
2024-10-03 13:17:58.314 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.tr064/4.2.0
2024-10-03 13:17:58.329 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.ui.basic/4.2.0
2024-10-03 13:17:58.337 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:58.338 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:58.339 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-34,name='/basicui',urlPatterns=[/basicui/manifest.json],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:58.341 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:58.341 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:58.342 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-35,name='/basicui/app',urlPatterns=[/basicui/app/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:58.344 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2024-10-03 13:17:58.348 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:58.349 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:58.350 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-27,name='/basicui/CMD',urlPatterns=[/basicui/CMD/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:58.351 [INFO ] [.service.internal.HttpServiceEnabled] - Unregistering servlet model "ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}"
2024-10-03 13:17:58.352 [INFO ] [jetty.internal.JettyServerController] - Receiving Batch{"Unregistration of servlets: [ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}]", size=1}
2024-10-03 13:17:58.352 [INFO ] [ce.jetty.internal.JettyServerWrapper] - Removing servlet ServletModel{id=ServletModel-28,name='default-03ebdd81-8f9a-4973-9792-987c7a73eaae',urlPatterns=[/basicui/*],contexts=[{WB,OCM-1,default,/}]}
2024-10-03 13:17:58.354 [INFO ] [internal.StoppableHttpServiceFactory] - Unbinding HTTP Service from bundle: [org.openhab.ui.basic_4.2.0 [271]]
