Hardware: raspberryPI 3 + Aeon Labs Z-stick gen 2
OS: Linux openHABianPi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
openHAB version: 2
I have a machine connected to a Fibaro FGWP102 Wall plug and had it running the entire day. The output of the logs looked like this:
2018-02-26 19:12:04.836 [vent.ItemStateChangedEvent] - m01_power changed from 960.1 to 960.7
2018-02-26 19:23:44.060 [vent.ItemStateChangedEvent] - m01_power changed from 960.7 to 959.9
2018-02-26 19:42:04.798 [vent.ItemStateChangedEvent] - m01_power changed from 959.9 to 960.5
2018-02-26 19:53:44.040 [vent.ItemStateChangedEvent] - m01_power changed from 960.5 to 958.8
2018-02-26 20:12:04.832 [vent.ItemStateChangedEvent] - m01_power changed from 958.8 to 959.1
2018-02-26 20:23:43.994 [vent.ItemStateChangedEvent] - m01_power changed from 959.1 to 960.9
2018-02-26 20:42:04.801 [vent.ItemStateChangedEvent] - m01_power changed from 960.9 to 958.5
2018-02-26 20:53:44.000 [vent.ItemStateChangedEvent] - m01_power changed from 958.5 to 960.2
2018-02-26 21:12:04.808 [vent.ItemStateChangedEvent] - m01_power changed from 960.2 to 958.9
2018-02-26 21:23:43.990 [vent.ItemStateChangedEvent] - m01_power changed from 958.9 to 959.2
2018-02-26 21:42:04.821 [vent.ItemStateChangedEvent] - m01_power changed from 959.2 to 957.9
So it seems that it sends a value every 11 minute or so, but not as defined in the configuration, when power changes 15% or more (settings 11, standard power report). And if I turn the switch off, it should send a high priority (setting 10, priority power report?) or at least know the power will drop to 0.
I rebooted the Pi, and I got two reports:
2018-02-26 22:00:05.107 [vent.ItemStateChangedEvent] - m01_power changed from NULL to 960
2018-02-26 22:00:06.091 [vent.ItemStateChangedEvent] - m01_power changed from 960 to 958.2
After this, nothing for more than 20 minutes. I’ll keep waiting to see if anything happens, but it doesn’t seem to follow it’s config.
Any help is appreciated!
