I’m using OH3 and define all my items and things through the UI …
I have a few items that have pre-defined strings when I click on the Item String in the UI … question is, can I create those for Items that I have defined and are not coming from a Binding?
That’s under the “Options” portion of the stateDescription metadata. You can use value=Label if you want machine friendly vs human readable values or you can just use a list of values if you don’t need the labels.
