Is there a corresponding ESH 0.9 (or the beta version that will be included with 2.2) draft release notes?
No, we should add such stuff to the openHAB release notes.
I was recently surprised when I started seeing a lot of these validation issues
That’s a good point. Yes, it probably should be mentioned - I tried to do so here. Not sure if this has any further impacts; if so, feel free to amend the wiki page.
That depends on how you installed it. If it is a manual installation, simply get the latest snapshot from here. If you use APT, check out the docs on how to switch the apt repo that is used.
I have some issues with groups needing a OH restart to populate changes.
@waitz_sebastian There was a fix on that about a month ago. If you see critical issues still on the latest snapshots, please let me know, I am not aware of any.
We have the upgrade script in place since early this year (runtime/bin/update) - is that what you are looking for? The info still needs to be added to the release notes though.
There should also be a note about breaking changes in logging configuration. (see Karaf Upgrade)
Right, but the note might depend on the outcome of this issue. But yes, definitely something that needs to be mentioned. Feel free to add it to the wiki page yourself!
It would be also helpful to tell users running OH 2.0 (and may be even 1.x) what to do, e.g. refer to previous release notes or start from scratch.
Yes, the two choices you mention are probably the best advice we could give. Can you add something to the wiki on that? Thanks!
Dec 18 is coming closer and out latest distro #1140 can be regarded as a kind of release candidate - it is pretty stable in all my testing over the past days and no bigger changes will be done to it anymore.
All remaining work is on the add-on side, where we will still accept bugfix PRs today and tomorrow.
So I’d like to ask all of you that are anyhow already snapshot builds to update to build #1140 and report any severe issues that you encounter; if any binding that you use is completely broken for some reason, please flag this asap, so that there is still a chance to fix it!
Note that the offline “addons” kar support should work as well again, so please go testing this, if you used it in the past.
@Kai : I just tested the new snapshot 1140 and the kar file. My feedback is positive. I have just encountered 1 issue which is apparently not new:
I am running the netatmo binding corresponding to the PR not yet merged. I will provide a feedback tomorrow morning. I hope this PR could be finally merged and included in the coming OH 2.2.
The old picture is deleted before the new one is displayed (-> results in flashing image)
With Snapshot #996 the picture is stable (not flushing at all)
/opt/openhab2/userdata/etc/shell.init.script
With snapshot #966 it was possible to put e.g.
log:tail-boot = { log:tail }
log:tail-boot
in the script file
wich executes log:tail after startup
this is no longer possible with #1140
is there another way to do this ?
