Preparing the openHAB 2.2 release
I jumped from S1137 to S1141 and I am testing things out.
So far, all works fine with:
bindings: 1x: knx,mqtt,weather, wol,networkupstools & 2x: zwave,samsungtv,astro,ntp,mpower,unifi
misc: homekit
actions: mail, pushover
persist: mapdb, influxdb
xform: json, map, regex
ui: basic, paper, habmin, habpanel
Main system on Debian 8 with Oracle’s 1.8.0_151 JVM
Additional tests on Raspberry Pi3 & Windows hosts look good also so far.
Only 1 significant ussue for me:
When restarting openhab2 it starts up in a certain state with certain configured bindings. Any new binding added after that state does not get activated or installed after the restart. I need to enable/install these missing bindings through console after each reboot.
I am running the latest version op openhabian.
@stefaanbolle : probably because you defined a particular bindings setup in your file addons.cfg. If you update this file with the new added bindings, these bindings will not be suppressed when you restart OH.
I was also suspecting this, however, I do not use the addons.cfg file
What exactly do you understand under “activated”? Is the binding installed, but the bundle not started?
How do you install them? Note that you indeed should not use the console, but either addons.cfg or the Paper UI.
Just updated to latest build.
All is working fine - upgrade went without any problems.
Just FYI geting the following error during openhab start:
2017-12-16 11:56:31.169 [ERROR] [g.eclipse.smarthome.config.discovery] - [org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl(44)] The addDiscoveryService method has thrown an exception
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.addDiscoveryService(DiscoveryServiceRegistryImpl.java:453) [107:org.eclipse.smarthome.config.discovery:0.10.0.b1]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:1556) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:261) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [45:org.apache.felix.scr:2.0.12]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1118) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) [45:org.apache.felix.scr:2.0.12]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [18:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [45:org.apache.felix.scr:2.0.12]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Thanks, @ip-ua, This has been already reported here: NPE in addDiscoveryService at startup · Issue #4751 · eclipse-archived/smarthome · GitHub
Do you see any functional impact from that?
No - just 10 minutes after upgrade went :slight_smile:
I’m on build 1140 and about to upgrade again,
On a 1140 yesterday, on the OH2 start, things looks Perfect. No errors, very nice clean log, But now this morning, I see some errors in the logs as follows.
Something do with Sitemaps? I don’t have anything named /home/0000 or home /00001
2017-12-16 05:47:38.979 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.11.123:8080/rest/sitemaps/home/0000
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions.  They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_865,866,1156953406) has been shut down
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
	at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions.  They are:
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
	... 13 more
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions.  They are:
	at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
	at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
	at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
	at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
	at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
	... 13 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_865,866,1156953406) has been shut down
	at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
	at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
	at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
	at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
	at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
	... 13 more
2017-12-16 05:47:39.014 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.11.123:8080/rest/sitemaps/home/00000001
@kai Can you take look at my latest post on this issue. NPE in addDiscoveryService at startup · Issue #4751 · eclipse-archived/smarthome · GitHub
I’m trying to determine if the behavior I’m seeing is related to the issue, or if it’s something different.
It would be great, if the changes to the KNX binding from August, that prevent the resending of received telegrams would be part of the 2.2 release.
Same thing for the changes to the homekit addon, that prevent loosing the room assignment of items after the items configuration has been changed.
I looked, but there seems to be no commit in the repository for either of the changes. Booth changes address (in my view) major issues.
If it helps: I am using “org.openhab.binding.knx-1.11.0-20170827” and “org.openhab.io.homekit-2.2.0-20171103”, booth provided somewhere in this forum, without any issues.
Probably worth mention this issue: [JDBC] - storeItemValueProvider does not store Time for DATETIMEITEM · Issue #5255 · openhab/openhab1-addons · GitHub
It causes changedsince rules to fail on datetime items because their time is always midnight when using jdbc persistence.
@juelicher If there are PRs available for fixes, discuss the progress directly there and make sure to have them reviewed, approved and tested ahead of time. Our deadline is tonight, so there are just 2 hours left now, so I don’t see much chance for the mentioned issues. But I’d hope we will be able to create a 2.2.1 patch release in a month or two, so you might want to get them in there.
@Moxified If there isn’t even anybody working on a fix for that issue yet, that looks even worse than @juelicher’s issues… Please follow up on the issue and find someone to fix it (if you can’t do it yourself).
At least for the KNX Binding there is a pull request from August, but I am not the author, so I don‘t really see what I could do about it…
Kai just want to say, screw the deadlines: The open-source way usually is: It’s ready when it’s ready. That’s the way it’s always been, and that’s okay, cause then I can trust it. Releasing before it’s ready is the Microsoft way… and we all know how stable that is.
I’ll rather wait a few more days, then a month or two for a patch release.
Yes, but it won’t help with juts two extra days when no pull request was yet created for an issue reported in august :slight_smile:
Very true. There’s always a limit too how long one can wait for others to fix stuff.
But for the KNX issues pull requests where created in August:
https://github.com/openhab/openhab1-addons/pull/5277
https://github.com/openhab/openhab1-addons/pull/5288
Why there is no pull request for the HomeKit binding, i do not know. The issue is discussed here:
https://github.com/openhab/openhab2-addons/issues/929
I know, that openHAB is an OpenSource project and a to know, that it is unfair to criticize when I myself, not being a Java developer, do not contribute code. But it is quite frustrating, that bug fixes for solved problems do not make it into the releases even month after there has been a solution…
I just tried snapshot #1141 but I cannot download any addons from the marketplace, the log says:
2017-12-18 11:16:41.847 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'other.items'
2017-12-18 11:16:54.472 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-12-18 11:16:54.526 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-12-18 11:17:05.677 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-12-18 11:17:05.723 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-12-18 11:17:05.833 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-12-18 11:17:24.472 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-ruleengine': Error:
	Error downloading mvn:org.eclipse.smarthome.automation/org.eclipse.smarthome.automation.api/0.10.0.b1
2017-12-18 11:17:39.221 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-ruleengine': Error:
2017-12-18 11:18:39.615 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-ruleengine': Error:
There are no such jars in the maven repository, do I have to add any custom addition to download the jars from jfrog etc.?
I also could not download the 2.2.0-snapshot anymore maybe its related to that.
I just installed the new release and can install marketplace bindings and the rule engine (note that the rule engine is not a real marketplace binding)
cc @Kai
