I have a Raspberry Pi3 running openHab 2.2.0 build, and I have some problems in my Rules…
So I have installed iCloud binding for my devices which works fine. I want to use these data mainly to detect presence (home or not). I have found a really good and easy rule here
However I can’t get working this rule… Here are my files:
distancehome.rules
Rule - Distance from home
This rule is triggered by an updated location item (Martin_Location). The location
item holds the coordinates to my iPhone and is updated by the Bridge/Thing in an
iCloud binding. The rule updates an item (Distance_From_Home) by calculating the
differene between two locations (a static HOME location and Martin_Location)
Pre-requisites
1. An .items file with the following content
Location Home_Location
Number Distance_From_Home
2. A configured Bridge/Thing using the iCloud binding with a location item (in this case Martin_Location)
rule "Distance from home"
Item KristofIPhone_Location changed
// Set the location for HOME (tip - use google maps to find the coordinates).
// The Norwegian Royal Palace (Lat, Lon)...
Home_Location.state = new PointType(new DecimalType(47.527496), new DecimalType(19.112647))
// Calculate the distance from HOME (Home_Location) and iCloud (Martin_Location)
Distance_From_Home.postUpdate(Home_Location.distanceFrom(KristofIPhone_Location))
// Optional logging to /var/log/openhab2/openhab2.log
logInfo("Distance from home : ", Distance_From_Home.state.toString())
rule "Home Or Away"
if((Distance_From_Home.state as NumberItem) < 100) {
KristofiPhone_Home.sendCommand(ON)
else {
KristofiPhone_Home.sendCommand(OFF)
This works somehow, because I have a sitemap which shows some data, but I don’t know what is the unit of this data… it shows around 20 when I’m home, and if I’m away from home (more than 10 km) it shows around 70…
Also the other rule at the end, doesn’t seems to work… It doesn’t show either on or off anytime.
If you look in here, you will see the comment that the distance is supposed to be in meters.
If that sounds wrong to you, you could post the 2 lat/longs used for a “false” calculation.
Also if you could help me… I have 3 iDevices which I have to use this presence detection. How can I make a universal rule for these 3 devices, so that I don’t have to make 3 individual rules… which is the easiest way?
Assuming all phones have associated items like
KristofiPhone_Location and KristofiPhone_Home
rule "Distances from home"
Item KristofiPhone_Location changed or
Item AdamiPhone_Location changed or
Item EveiPhone_Location changed
// specify your home location
val PointType home_location = new PointType(new DecimalType(51.0), new DecimalType(4.0))
val PointType phone_location = triggeringItem.state as PointType
val nameParts = triggeringItem.name.split("_")
val triggeringiPhoneName= nameParts[0]+"_Home"
val int distance = phone_location.distanceFrom(home_location).intValue()
// specify your preferred radius (in meters)
if ( distance < 200) {
postUpdate(triggeringiPhoneName,ON)
logInfo(nameParts[0], "is at home.")
} else {
postUpdate(triggeringiPhoneName,OFF)
logInfo(nameParts[0], " is away.")
2018-03-28 18:05:10.311 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘iPhone Home’: The name ‘nameParts’ cannot be resolved to an item or type; line 10, column 29, length 12
I got this error, at this line:
val triggeringiPhoneName = nameParts[0] + “_Home”
2018-03-28 19:16:02.766 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘iPhone Home’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(java.lang.String,java.lang.String) on instance: null
…and for the distance calculation I just tested it with thre values from to 55.0 / 5.0 to 56.0 /5.0 and got a value of 111319m. Converting that to Nautical miles give me 60,1074514, which is pretty close to the expected 60 Nm (Distance from 55N to 56N due is 1° or 60 Nm).
In short: Correct!
This rule is working fine, but it has a minor problem. The phone sometimes loses precise location so it detects that the phone is not at home. (Accuracy ~1500m)
How can I use the location accuracy to include it in the distance?
What I would want is something like:
rule "iPhone Home"
Item KristofIPhone_Location changed or
Item EdinaIPhone_Location changed or
Item ReKaIPhone_Location changed
val PointType home_location = new PointType(new DecimalType(47.5274), new DecimalType(19.1126))
val nameParts = triggeringItem.name.toString.split("_")
val triggeringiPhoneName = nameParts.get(0) + "_Home"
val DecimalType locationAccuracy = nameParts.get(0) + "_LocationAccuracy"
if(distance < 150) {
postUpdate(triggeringiPhoneName, "ON")
logInfo(nameParts.get(0), "iPhone is at home.")
} else {
postUpdate(triggeringiPhoneName, "OFF")
logInfo(nameParts.get(0), "iPhone is away.")
So I want to use that LocationAccuracy (which is a Number type item) to include it somehow in detection. I thought of distance < 150 + LocationAccuracy or something like this, however it doesn’t seem to work
