I started using homekit to monitor my presence at home.
As homekit works quite well for me now I started something new.
I mainly use homekit with dummy-switch-items (with no binding) to activate and deactivate scenes I defined with rules.
This way I use it for lights, hue-lights, blinds, heating, sonos, harmony hub and hyperion ambilight.
I started using owntracks for presence detection, but I discovered that it is also possible and maybe much easier to use actions in the home app on the iPhone:
I again used dummy-items:
I use 2 groups, because I use the iPhones to detect if am in the zone around the house and how many.
Only when my main door opens I set my presence to ON
rule "Anwesenheit ein"
Item MainDoor changed to OPEN
if (gAnwesenheit == ON) {
Anwesenheit.sendCommand(ON)
rule "Anwesenheit aus"
Item gAnwesenheit changed to OFF
Anwesenheit.sendCommand(OFF)
On my iPhone it was very easy:
Just setting up 2 actions, one for leaving the home zone and one for entering the home zone and switching the my dummy item OFF or ON
For the iPhone of my wife I had to invite her in the home app to our house and give her the right to make changes.
Then she had to set up the 2 actions in her home app using her dummy item.
The actions show up in the home app on both iPhones but really work independently.
Have you noticed a big change in your battery life after getting this set up? I thought about doing something similar but didn’t want to burn through my battery.
I use the iOS location service (geofency, owntracks, reminders …) since a long time now and I do not experience a major impact on battery life.
Once you started using this service in iOS it does not matter how many apps are using it
@Dome and LuFriFri
Did you find a way how Geofency can communicate to OPENHAB directly without the support of a “protocol translation” service by a server on the internet.
No, I did not find a way to do that.
I used Geofency with iobroker, but had to open a port on my router.
I read that one can connect iobroker to openhab, perhaps that helps?
I got this solution working with the “switchable” items. They are working by pressing the switches manually but i´ve another problem. The automation rule in the apple home app can´t be activate…
I´m really confused about that…
At home there is a Ipad mounted on wall and it is running as the “Main device”
