I thought this would be straight forward but seems im missing something.
I’m trying to get Alexa to say something when my Mobile goes online (as in i’ve arrived at home) and i’ve walked past the motion sensors (not point saying welcome, unless one of the two motion sensors trip) which indicates im close to the Alexa dot
Any thoughts?
rule "Play Welcome Message when Kris enters the House"
Item Kris_Mobile changed to ON
if (BackEveMotionAlarm == ON || FibaroEye1Motion == ON) {
logInfo("Mobile Presense", "Kris has entered the Home")
Echo_Living_Room_TTS.sendCommand('Welcome Home Kris')
What is the control factor for your Kris_Mobile item?
For example if you are using the iCloud binding for this it takes time for the data to update. Might also be helpful to do multiple logInfo lines to know if any part of the then statement is triggering.
With the if statement using or then Alexa should respond when you mobile go online. If your not near the echo you may not hear the message. You can change the or (||) to and (&&) so that both conditions must be met before the message is sent. I use Alexa to notify me if there is movement in my garage, when the door is open, and it works good. I also included motion detection suspension for going in the garage without Alexa alerting every 15 seconds. Here’s an example of the rule I use, maybe it can help give you some ideas.
var Timer stopMotionTimer = null
var Timer startMotionTimer = null
var Timer startLightTimer = null
val int timeoutMinutes = 60
rule "Detect Motion when Garage is Open"
Item Esp_Easy_Motion changed from OFF
if(Proxy_Motion.state == ON && stopMotionTimer === null && ESP_Easy_Door.state == OFF){ // Door open = OFF
Echo_Plus_TTS.sendCommand('Alert, garage movement!')
stopMotionTimer = createTimer(now.plusSeconds(15)) [|
rule "Auto ON Garage Motion Detection after One Hour when Garage is Open"
Item Proxy_Motion changed from ON to OFF
if(startMotionTimer === null && Proxy_Motion.state == OFF){
Echo_Plus_TTS.sendCommand('The garage motion suspended for one hour')
startMotionTimer = createTimer(now.plusMinutes(60)) [|
Proxy_Motion.sendCommand(ON)
Echo_Plus_TTS.sendCommand('Garage motion is now on')
rule "Garage Light Detection"
Item Esp_Garage_Lightlevel received update
val Val_Light = Esp_Garage_Lightlevel.state as Number
if(Val_Light >= 650 && ESP_Easy_Door.state == ON && startLightTimer === null){
startLightTimer = createTimer(now.plusSeconds(190)) [|
Echo_Plus_TTS.sendCommand('The garage door is closed, and light has been left on')
if(Val_Light <= 500){
Proxy_Lightlevel.postUpdate(ON)
I think the fundamental problem is you can’t really control the order of the events. There can be times where the BackEveMotionAlarm goes to ON or FibaroEye1Motion goes to ON after Kris_Mobile changes to ON. In that case the Alexa will never say the greeting.
So I think you need to trigger the Rule on any of these three events taking place and then send the message to talk if one of the motion sensors is ON and Kris_Mobile is ON and they both turned on within a certain amount of time ago.
Also, you need to check the state of the Items in your if statement.
The below requires persistence on Kris_Mobile configured with everyChange, not everyMinute.
Item Kris_Mobile changed to ON or
Item BackEveMotionAlarm changed to ON or
Item FibaroEye1Motion changed to ON
if(Kris_Mobile.state != ON) return;
if(BackEyeMotionAlarm.state != ON || FibaroEye1Motion.state != ON) return;
val lu = new DateTime(Kris_Mobile.lastUpdate.toString)
if(lu.isAfter(now.minusSeconds(20)) {
ive started to test this rule but I get this error in the log, seems date/time related?
13:28:28.736 [WARN ] [ence.extensions.PersistenceExtensions] - There is no default persistence service configured!
13:28:28.738 [WARN ] [ence.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'null'
13:28:28.739 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Play Welcome Message when Kris enters the House': cannot invoke method public java.lang.String org.joda.time.base.AbstractInstant.toString() on null
rule:
if(BackEveMotionAlarm.state != ON && FibaroEye1Motion.state != ON) return;
if(lu.isAfter(now.minusSeconds(20))) {
Kris_Mobile is not being saved to persistence. You must set up persistence and configure it to save Kris_Mobile on every change in order for the Rule to work. The error is telling us that Kris_Mobile.lastUpdate is returning null and null doesn’t have a toString method.
