Please try this jar file to login:
Link removed.
This version is for test only.
Edit: Could produce captcha, renew password and OTP
br
Link removed.
br
I am able to log in again with this latest version you have posted. ![]()
I am still experiencing the problem however where “LastVoiceCommand” and TTS are delayed or don’t always work. The “LastVoiceCommand” is delayed sometimes by as long as 20 second, whereas it is normally instantaneous. My volume is up all the way.
I enabled trace logging for the binding but it is not showing anything abnormal, it is just slow to show the HTTP request updates in the log from the Amazon servers. I can provide any other information that may be helpful. Thank you again!
Edit: For now, I was able to use your latest binding version to login to my Amazon Account Thing and then replaced/downgraded the .jar file with the last version from @J-N-K that worked perfectly for me, which is the org.openhab.binding.amazonechocontrol-2.5.6-f4.jar file. I’m happy to switch back to the latest .jar and test anything/provide logs.
I have been able after a couple of time to log in via the proxy.
And is working ok here..but I espect it’ll break again.
Amazon is now sending me a sms each time to approve it is me each time i try to log on amazon shopping site:o
No success, I changed the jar file without restarting first and got something like “not in initialization mode”. After a restart of openHAB, I get the “Enter a valid mail or password” message.
Same problem here - after otp and password change at my side it comes ..:
HTTP ERROR 500
Problem accessing /amazonechocontrol/c657026b/ap/forgotpassword. Reason:Server ErrorCaused by:
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url ‘https://www.amazon.com/ap/forgotpassword’ failed: Not Found
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:648)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:631)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doVerb(AccountServlet.java:228)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doPost(AccountServlet.java:136)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:494)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
at java.lang.Thread.run(Thread.java:748)
Just tried the new .jar with another Amazon Account.
First I got the “change your password” message.
After changing the password I also got “Enter a valid email or password” for this account.
EDIT 08:00 a.m.: Finally I was nearly able to login. I was shown a page with “password assistance”, then I was asked for my ZIP code, had to enter a captcha, a OTP was sent…and after that I got the same message as @black0r1337
This happened after the fifth or sixth attempt to login, so it seems for any reason my password seems to be recognized as wrong, although it is definitely correct and then I am sent to this “password assistance” page.
This worked for me right now. I was able to login.
THANKS!
After the new *.jar from @Trinitus01 i got sign in (after a few trys) than password reset and cptcha and OTB after that i got following:
HTTP ERROR 500
Problem accessing /amazonechocontrol/c657026b/ap/signin/136-4139178-6507409. Reason:
Server Error
Caused by:
javax.servlet.ServletException: java.net.UnknownHostException: www.amazon.com
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88)
Caused by: java.net.UnknownHostException: www.amazon.com
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:607)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666)
at sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:173)
at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1162)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1056)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1340)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1315)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:264)
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:581)
... 15 more
Caused by:
Powered by Jetty:// 9.4.20.v20190813
and OH2 Log:
2020-07-16 11:49:20.989 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /amazonechocontrol/c657026b/ap/forgotpassword
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:648) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:631) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doVerb(AccountServlet.java:228) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doPost(AccountServlet.java:136) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[bundleFile:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[bundleFile:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) ~[bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) ~[bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Randomly, my AmazonEchoControl binding "SmartHomwDevices have stopped working and I am receiving the errors below. It does not matter which version of the binding I use.
20│2020-07-16 04:29:06.137 [ERROR] [trol.internal.handler.AccountHandler] - check login fails with unexpected error │
20│java.lang.NullPointerException: null │
20│ at java.net.URLEncoder.encode(URLEncoder.java:204) ~[?:1.8.0_252] │
20│ at org.openhab.binding.amazonechocontrol.internal.Connection.exchangeToken(Connection.java:783) ~[?:?] │
20│ at org.openhab.binding.amazonechocontrol.internal.Connection.checkRenewSession(Connection.java:835) ~[?:?] │
20│ at org.openhab.binding.amazonechocontrol.internal.Connection.tryRestoreSessionData(Connection.java:424) ~[?:?] │
20│ at org.openhab.binding.amazonechocontrol.internal.Connection.tryRestoreLogin(Connection.java:346) ~[?:?] │
20│ at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkLogin(AccountHandler.java:385) ~[?:?] │
20│ at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_252] │
20│ at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_252] │
20│ at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_252] │
20│ at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_252] │
20│ at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252] │
20│ at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252] │
20│ at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252] │
00│2020-07-16 04:29:42.842 [INFO ] [mazonechocontrol.internal.Connection] - Smart home device command failed. │58
│2020-07-16 04:29:42.843 [INFO ] [mazonechocontrol.internal.Connection] - Request: │
20│2020-07-16 04:29:42.843 [INFO ] [mazonechocontrol.internal.Connection] - {"controlRequests":[{"entityId":"e60e8fda-2a0e-46fd-9713-1e904556149a","entityType":"APPLIANCE","parameters":{"action":"turnOn"}}]} │
20│2020-07-16 04:29:42.844 [INFO ] [mazonechocontrol.internal.Connection] - Answer: │
20│2020-07-16 04:29:42.845 [INFO ] [mazonechocontrol.internal.Connection] - {"entity":{"entityId":"e60e8fda-2a0e-46fd-9713-1e904556149a","entityType":"APPLIANCE"},"code":"INVALID_DIRECTIVE","message":null,"data":nu│
20│ll} │
20│2020-07-16 04:29:44.617 [INFO ] [mazonechocontrol.internal.Connection] - Smart home device command failed. │
20│2020-07-16 04:29:44.618 [INFO ] [mazonechocontrol.internal.Connection] - Request: │
20│2020-07-16 04:29:44.619 [INFO ] [mazonechocontrol.internal.Connection] - {"controlRequests":[{"entityId":"e60e8fda-2a0e-46fd-9713-1e904556149a","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]} │
20│2020-07-16 04:29:44.620 [INFO ] [mazonechocontrol.internal.Connection] - Answer: │
20│2020-07-16 04:29:44.620 [INFO ] [mazonechocontrol.internal.Connection] - {"entity":{"entityId":"e60e8fda-2a0e-46fd-9713-1e904556149a","entityType":"APPLIANCE"},"code":"INVALID_DIRECTIVE","message":null,"data":nu│
20│ll} │
20│2020-07-16 04:29:51.492 [INFO ] [mazonechocontrol.internal.Connection] - Smart home device command failed. │
20│2020-07-16 04:29:51.493 [INFO ] [mazonechocontrol.internal.Connection] - Request: │
20│2020-07-16 04:29:51.493 [INFO ] [mazonechocontrol.internal.Connection] - {"controlRequests":[{"entityId":"e758d86e-40a1-4415-886c-397c71939635","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}
And now also:
2020-07-16 04:41:23.432 [hingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDevice:0654f2d8:Stairs_Light_Master' changed from OFFLINE: Can't find smarthomeBaseDevice! to OFFLINE: Can't find smarthomeBaseDevice
2020-07-16 04:41:34.893 [hingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDevice:0654f2d8:Stairs_Light_Master' changed from OFFLINE: Can't find smarthomeBaseDevice to OFFLINE: Can't find smarthomeBaseDevice!
2020-07-16 04:41:36.649 [hingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDevice:0654f2d8:Stairs_Light_Master' changed from OFFLINE: Can't find smarthomeBaseDevice! to OFFLINE: Can't find smarthomeBaseDevice
2020-07-16 04:41:45.569 [hingStatusInfoChangedEvent] - 'amazonechocontrol:smartHomeDevice:0654f2d8:Stairs_Light_Master' changed from OFFLINE: Can't find smarthomeBaseDevice to OFFLINE: Can't find smarthomeBaseDevice!
That worked for me. First time I could login after a week of outage.
I try to reduce the delay.
Do you send the tts to a group or multiple devices?
Do you send multiple tts with different sentences to different devices?
Did you take the time via log or did you count?
Because there could also a delay between the state update and the rule trigger.
I still don’t know your test case and you still didn’t provide a log.
So i am not able to see the problem and its nearly impossible to say whats the reason.
20 Seconds doesn’t seem that much compared to loosing a tts because amaz*n reject it.
Without a delay the tts is lost…
br
can you please test the following jar file:
Link removed. New version to test will follow soon.
Please focus on the login, there should no issue anymore.
(Catcha and OTP is possible and ok)
Big thanks!
br
No luck from my side.
For both accounts still “Enter a valid email or mobile number”, after five tries I am brought back to password assistance, as if I would have used a wrong password (of course I did not), so my password seems not to be recognized.
No matter which device or browser I use.
I am just wondering…this Amazon account number…I can’t remember where I got it from or how it was generated. Can someone tell me from where I got it?
When I try to complete the forgotten password process the log shows this:
2020-07-16 19:22:01.774 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /amazonechocontrol/21242853/FORWARD/ap/forgotpassword
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://www.amazon.com/ap/forgotpassword?arb=53288ada-d0ab-46b1-9af1-f7639a311438&claimToken=eyJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiUlNBLU9BRVAifQ.c0ahuuiIS_DtcmiEO69XV0zXUlj5lduMBdvVC9UrApru7OFW65DDQM3KdNDkoUxAgCVxG3doUGGw6VLZ4qEtNYoWZw-nHlHeHnMkynwjN5hoF3IO-FNmQmhKLbBkMLGHuqkA3W55LQy8n3AZVGttfRc6d5CsjKUQ06Wx-tdJ4LA5llm8lMnoaJoIAKtaR7dnf0S6go_4X_w_h4z3jq6RfmzLMoSazZBWwSg4AcavEa8DTBJebOc8L9kdPt183mBgzTS7kFEybGfvL2o71qr9B75ehHsUFcBHVrX5uN7UJe7S3LxSIycPp1FHa3XP0_TSDbp5h6rAl56k__Chq3uL-g.b4uWf7jTWV8t2yaj.iGaRmplyI4e778z-HNseGgDaqOLUxImhR8MXzX0IU2fGshK2Y7dmenOUQUL2PM9j20mZ8K2D9SfgAjQiMQOtl2S-qU2ef-GS1VwqaDWEOmJlf9UFGJ2Bl5zoneBb2Mrch-LD4nw-VXV-zj0HH_pLm-29Lw-cgb0lzogfQZueM4Pbf7c14azuZNvul0Pnilk90yozlwqIf-C3wQ9GkRUQXIdAVisPJqe39pgBMyEFau6juHTy6DO9NzbmEb4NqCkGO-my9biN3AU9VJIvR5alvuDjVa9grKVHJ-sug43tTUpZ8U5b2dVitmJBKIK5rAgw0JWeunPTPqKxu4OqgMZDIczQqqPoBxuW_tIF12gVOZMPp56zAerctfLScvj5WhB3KFhWa82r32cFMHw2Ld4K7uCSrp-uJJ4NuIXYCviDFUsCWxOlX2_do34mtcC2PWhdV4NuAhwYdg7Chz6nBNltrWFFWnJPxWub1_6W2i4q4xGJ7xVPXiXVNBKG_DtVkUNrRyVwi87-9Mjb3ecvyDAMLbB5MSnVrdwlNeSrBamf685AdryFRoimPFkurXeRWR_E0AuGywmn8KOJ5_GIu8hph4XFUs8uPqyG-N7DROMdLFjyzyXIJoW1LpxBd9RaMwg0bNExKEgfC-lx2RzrMVzWvFm4SCqlHLJmnvQN_oXd5vNe9pjqozoh1uX-3wZss2NvsSJNHecB35D7KGRPD0t6xrYHVq7hI19MCjTS2Ch8cH8S9_znH24EIUXBKOp0_wXzbK2w5oFzg3sSXBryTnHHEEJKaZ8rvMeL6-axOJYGVYy6MB5oBoT7SfijgFuxzwm3kzeurcb0GUhf5qugn7lh8kK2Xs4_Hi7oabmx9tsSXFu3zVGYHgpS5GCyQj31Kv4lY1w5E5sm5Joaf6SE94LXIDFd-gcFBUjI8TfqL1cTBexckwyYQVEhv6nP5M6_y1s1gByCxFgOmJOHhitzsDqaQoVyBdfup4_ijNySoj0UPm2XkYXOGM1jghS0beaPa1ugL7wtNdfYirpgx6CT7LvKUXOyp5-NgDFXRLc3F3_m67vY7FpcaN-3F9VW2xIHckFBQHhb5uPnXoGN_Nd6E05aoFjx-It47zNZWmP-Y-0lK6XHupoXGBtLOezGewmxBfLNRc5vG4dtj7lsv5Jx3YuRjVgppLDU6wQF7SXd3sUGcUYZJVziWKBnJRzuBbASrMKkTkoInK7pctHyV32ud5jtWo7WKdG49FU4ltjJkJc4h8hvaieVJ4sHVOoEiPoGs_TRKmPIRwnXVrFsUVjI--6003WbT-5RwffLQBmidiZHzIi_OpbvbpBt-dXgW-JF8vC92pRtyyaGZrN4FxddIaAGg4qwKADW8nReoELsVxhfQSDl7W-uAcNJNkMUbrpOfm7etEpEXyArpu0Gs6qiXMFwkS5CCX392T1_7JUcxkm8UerztTL9i9o3MxD9w4g0Ae08vRa56eoBbT-jGIpE2vvWlCy9KlOF7zUhwtcEpiZnqtdajYJbVyTa2Q-BW7NSu_-_2WYSeqHHL3o_I-tIbJopJDLenVUAwc72fgnoINExNb0VkE2QEf4CA9lRvh32PwxlbGIDuhGfrEti8fVfTpxPys4YvHoi3Q.C3ydCAVId52sr0a_55N72A' failed: Not Found
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:675) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:629) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doGet(AccountServlet.java:245) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
As i wrote in a previous post, you have to got to the amazon website and login. Because your account is in a bad state. Follow the steps and reset your pw. After it, go back to the Bindings login website and try again, it should work.
br
I changed my password already three times today on amazon.de and two times on amazon.com.
I can login without a problem on both websites, I am only sent an OTP (code to my mobile phone) every time I try to login.
I am getting out of ideas for new passwords.
This is strange. Are you sure the new jar is loaded?
Remove the jar, check the log, add the jar check the log again.
I removed the jar, uninstalled the binding via the console, copied the new jar to the folder and restarted openHAB, but I will check again.
This is what happens when I copy the jar to the folder again:
2020-07-16 19:38:58.787 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:21242853:e61e30bb492a455697891d60db8067a9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.792 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090L91174170WWJ' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.797 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:21242853:1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.802 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090XG0794142M3J' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.811 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G000JN0674330DMN' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.813 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G0911B0593170050' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-07-16 19:38:58.926 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:21242853' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-07-16 19:38:58.990 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:21242853' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): Wait for login
2020-07-16 19:38:59.013 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:21242853:1' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.065 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:21242853:e61e30bb492a455697891d60db8067a9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.078 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:21242853:1' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.106 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:21242853:e61e30bb492a455697891d60db8067a9' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.116 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090P308747213W3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-07-16 19:38:59.121 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G000JN0674330DMN' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.128 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090XG0794142M3J' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.135 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090L91174170WWJ' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.160 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090P308747213W3' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.168 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G000JN0674330DMN' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.176 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090XG0794142M3J' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.183 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090L91174170WWJ' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.188 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G0911B0593170050' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-07-16 19:38:59.201 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G0911B0593170050' changed from INITIALIZING to UNKNOWN
2020-07-16 19:38:59.825 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:21242853' changed from OFFLINE (CONFIGURATION_PENDING): Wait for login to OFFLINE (COMMUNICATION_ERROR): POST url 'https://api.amazon.com/auth/token' failed: Bad Request
2020-07-16 19:38:59.831 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090L91174170WWJ' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.834 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:21242853:e61e30bb492a455697891d60db8067a9' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.839 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090XG0794142M3J' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.841 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:21242853:1' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.844 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G000JN0674330DMN' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.847 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echoshow:21242853:G0911B0593170050' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2020-07-16 19:38:59.850 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:21242853:G090P308747213W3' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
Is this ok or does it have to say anything like “…is loaded”?
It’s my first time working with a jar.
The active version is 2.5.7.202007161601
Check bundle:list | grep -i amazon to see which version is running.
I now set up a fresh installation of openHABian and I was able to login again.
There seems to be something wrong with my old installation…
