I’m on the Raspberry Pi 3 Motherboard B and I installed openHAB 2 via these instructions: http://docs.openhab.org/installation/rasppi.html
Unfortunately, when I access through the web interface, I’m getting
Problem accessing /start/index. Reason:
Not Found
This is my java version:
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
I believe I have OracleJDK installed instead of OpenJDK since I know it causes problems. Aside from seeing the Not Found
error through the web interface, I’m also seeing this when running start_debug.sh
manually:
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.0.0.b3
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> [Fatal Error] :1:3: The markup in the document preceding the root element must be well-formed.
I’m also seeing this error in my logs
2016-06-19 23:36:49.230 [ERROR] [org.eclipse.smarthome.model.script ] - [org.eclipse.smarthome.action.transformation.action(82)] Circular reference detected, getService returning null
Anyone know why this could be happening? I’ve tried waiting 5 minutes to wait for openHAB 2 to boot up but nothing changes. Thank you!
