Problem building android app from source
Hi, I’ve problems building the android app from source.
I’m getting an exception: “com.android.dex.DexIndexOverflowException: method ID not in [0, 0xffff]: 65536”.
Has anyone manage to build the master version of habdroid without problems?
I have a fix that will allow me to build, but I’m not sure if that is a correct fix: Step android gradle plugin version to 1.5.0 · hazzeh/openhab.android@9913fbe · GitHub
This commit also steps the android gradle plugin version to one that is accepted by newer android studio versions.
If it is a valid correction I can create a pull request.
BR,
Hans
I had the same error, adding
multiDexEnabled true resolve compilation problem.
We also should change extends of org.openhab.habdroid.core.HABDroid to android.support.multidex.MultiDexApplication to support older version of Android.
I prepared similar commit:
@maintainer - does anybody maintain android project? - I see only one @belovictor
That looks good, it would be nice if it can be merged into master. Then I can rebase my pull requests for fixing issue #153.
