Hi!
I’m installing OH2 snapshot from today in one clean installation of Lubuntu.
On first launch I installed the expert package, and on paper UI added the cloud connector.
With the newly generated UUID and secret I had updated this key on my account on myopenhab.org account.
After restarting the openhab several times, on cloud i’m unable to establish one connection.
Here is my log:
2017-01-15 12:18:36.899 [DEBUG] [org.openhab.io.jetty.certificate ] - BundleEvent STARTING - org.openhab.io.jetty.certificate
2017-01-15 12:18:36.987 [DEBUG] [ficate.internal.CertificateGenerator] - Keystore found. Trying to load /var/lib/openhab2/etc/keystore
2017-01-15 12:18:37.004 [DEBUG] [ficate.internal.CertificateGenerator] - mykey alias found. Do nothing.
2017-01-15 12:18:37.007 [DEBUG] [org.openhab.io.jetty.certificate ] - BundleEvent STARTED - org.openhab.io.jetty.certificate
2017-01-15 12:19:16.309 [DEBUG] [org.openhab.core.karaf ] - ServiceEvent REGISTERED - {org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener}={misc=restdocs,myopenhab, component.name=org.openhab.addons, remote=true, service.config.category=system, service.config.description.uri=system:addons, felix.fileinstall.filename=file:/var/lib/openhab2/etc/org.openhab.addons.cfg, service.pid=org.openhab.addons, service.config.label=Add-on Management, transformation=map,regex,xslt,exec,javascript,scale,xpath,jsonpath, ui=classic,basic,paper,habpanel,habmin, component.id=134, package=expert, service.id=262, service.bundleid=167, service.scope=bundle} - org.openhab.core.karaf
2017-01-15 12:19:16.397 [DEBUG] [org.openhab.core.karaf ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.extension.ExtensionService}={component.name=org.openhab.core.karafextension, component.id=135, service.id=263, service.bundleid=167, service.scope=bundle} - org.openhab.core.karaf
2017-01-15 12:19:16.421 [DEBUG] [org.openhab.core.karaf ] - BundleEvent STARTING - org.openhab.core.karaf
2017-01-15 12:19:16.508 [DEBUG] [org.openhab.core.karaf ] - BundleEvent STARTED - org.openhab.core.karaf
2017-01-15 12:19:17.047 [DEBUG] [org.openhab.ui.dashboard ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.ui.dashboard, osgi.web.version=2.0.0.201701141030, osgi.web.contextpath=/, service.id=264, service.bundleid=170, service.scope=singleton} - org.openhab.ui.dashboard
2017-01-15 12:19:17.187 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-01-15 12:19:17.189 [DEBUG] [org.openhab.ui.dashboard ] - BundleEvent STARTING - org.openhab.ui.dashboard
2017-01-15 12:19:17.193 [DEBUG] [org.openhab.ui.dashboard ] - BundleEvent STARTED - org.openhab.ui.dashboard
2017-01-15 12:19:17.247 [DEBUG] [org.openhab.core.compat1x ] - BundleEvent STARTING - org.openhab.core.compat1x
2017-01-15 12:19:17.432 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.openhab.core.events.EventPublisher}={component.name=org.openhab.core.compat1x.eventpublisherdelegate, component.id=137, service.id=265, service.bundleid=176, service.scope=bundle} - org.openhab.core.compat1x
2017-01-15 12:19:17.709 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.eclipse.smarthome.core.events.EventSubscriber}={event.topics=smarthome/*, component.name=org.openhab.core.compat1x.eventbridge, component.id=139, service.id=266, service.bundleid=176, service.scope=bundle} - org.openhab.core.compat1x
2017-01-15 12:19:17.798 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.autoupdate.AutoUpdateBindingConfigProvider}={component.name=org.openhab.core.compat1x.autoupdateproviderdelegate, component.id=143, service.id=267, service.bundleid=176, service.scope=bundle} - org.openhab.core.compat1x
2017-01-15 12:19:18.032 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.openhab.core.items.ItemRegistry, org.openhab.ui.items.ItemUIRegistry}={component.name=org.openhab.core.compat1x.itemuiregistry, component.id=144, service.id=268, service.bundleid=176, service.scope=bundle} - org.openhab.core.compat1x
2017-01-15 12:19:18.036 [DEBUG] [org.openhab.core.compat1x ] - BundleEvent STARTED - org.openhab.core.compat1x
2017-01-15 12:19:20.511 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-01-15 12:19:21.275 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-01-15 12:19:22.246 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-01-15 12:19:22.274 [DEBUG] [org.openhab.io.rest.docs ] - BundleEvent STARTING - org.openhab.io.rest.docs
2017-01-15 12:19:22.492 [DEBUG] [org.openhab.io.rest.docs ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.io.rest.docs, osgi.web.version=2.0.0.201701141030, osgi.web.contextpath=/, service.id=310, service.bundleid=200, service.scope=singleton} - org.openhab.io.rest.docs
2017-01-15 12:19:22.498 [DEBUG] [org.openhab.io.rest.docs ] - ServiceEvent REGISTERED - {org.openhab.ui.dashboard.DashboardTile}={component.name=org.openhab.io.rest.docs.dashboardtile, component.id=182, service.id=309, service.bundleid=200, service.scope=bundle} - org.openhab.io.rest.docs
2017-01-15 12:19:22.508 [DEBUG] [org.openhab.io.rest.docs ] - BundleEvent STARTED - org.openhab.io.rest.docs
2017-01-15 12:19:22.512 [DEBUG] [org.openhab.ui.classicui ] - BundleEvent STARTING - org.openhab.ui.classicui
2017-01-15 12:19:22.546 [DEBUG] [org.openhab.ui.classicui ] - ServiceEvent REGISTERED - {org.openhab.ui.dashboard.DashboardTile}={component.name=org.openhab.ui.classicui.dashboardtile, component.id=183, service.id=311, service.bundleid=202, service.scope=bundle} - org.openhab.ui.classicui
2017-01-15 12:19:22.552 [DEBUG] [org.openhab.ui.classicui ] - BundleEvent STARTED - org.openhab.ui.classicui
2017-01-15 12:19:22.564 [DEBUG] [org.openhab.ui.habmin ] - BundleEvent STARTING - org.openhab.ui.habmin
2017-01-15 12:19:22.733 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={component.name=org.openhab.ui.habmin.floorplan, component.id=184, service.id=312, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:22.743 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.openhab.ui.dashboard.DashboardTile}={component.name=org.openhab.ui.habmin.dashboardtile, component.id=185, service.id=313, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:22.797 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={component.name=org.openhab.ui.habmin.designer, component.id=186, service.id=314, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:22.994 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.ui.habmin, osgi.web.version=2.0.0.201701141030, osgi.web.contextpath=/, service.id=315, service.bundleid=203, service.scope=singleton} - org.openhab.ui.habmin
2017-01-15 12:19:23.018 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-01-15 12:19:23.072 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={component.name=org.openhab.ui.habmin.rules, component.id=188, service.id=316, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:23.142 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={component.name=org.openhab.ui.habmin.dashboard, component.id=189, service.id=317, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:23.187 [DEBUG] [org.openhab.ui.habmin ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.rest.RESTResource}={component.name=org.openhab.ui.habmin.charts, component.id=190, service.id=318, service.bundleid=203, service.scope=bundle} - org.openhab.ui.habmin
2017-01-15 12:19:23.200 [DEBUG] [org.openhab.ui.habmin ] - BundleEvent STARTED - org.openhab.ui.habmin
2017-01-15 12:19:23.208 [DEBUG] [org.openhab.ui.habpanel ] - BundleEvent STARTING - org.openhab.ui.habpanel
2017-01-15 12:19:23.490 [DEBUG] [org.openhab.ui.habpanel ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.ui.habpanel, osgi.web.version=2.0.0.201701141030, osgi.web.contextpath=/, service.id=320, service.bundleid=204, service.scope=singleton} - org.openhab.ui.habpanel
2017-01-15 12:19:23.493 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-01-15 12:19:23.496 [DEBUG] [org.openhab.ui.habpanel ] - ServiceEvent REGISTERED - {org.openhab.ui.dashboard.DashboardTile}={service.config.category=ui, service.config.label=HABPanel, component.name=org.openhab.ui.habpanel, component.id=191, service.config.description.uri=ui:habpanel, service.id=319, service.bundleid=204, service.scope=bundle} - org.openhab.ui.habpanel
2017-01-15 12:19:23.497 [DEBUG] [org.openhab.ui.habpanel ] - BundleEvent STARTED - org.openhab.ui.habpanel
2017-01-15 12:19:23.580 [DEBUG] [org.openhab.io.myopenhab ] - BundleEvent STARTING - org.openhab.io.myopenhab
2017-01-15 12:19:23.677 [DEBUG] [.myopenhab.internal.MyOpenHABService] - my.openHAB service activated
2017-01-15 12:19:23.778 [DEBUG] [.myopenhab.internal.MyOpenHABService] - Using secret at '/var/lib/openhab2/myopenhab/secret' with content 'PZcpaw3skipCl441kh3W'
2017-01-15 12:19:23.820 [DEBUG] [.myopenhab.internal.MyOpenHABService] - UUID = 890ac19c-1631-4e78-b462-aaf03cf97b6e, secret = PZ********************3W
2017-01-15 12:19:23.949 [DEBUG] [.myopenhab.internal.MyOpenHABService] - Using secret at '/var/lib/openhab2/myopenhab/secret' with content 'PZc**********************3W'
2017-01-15 12:19:24.102 [DEBUG] [org.openhab.io.myopenhab ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.persistence.PersistenceService, org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.pid=org.openhab.myopenhab, service.config.category=io, service.config.label=my.openhab, component.name=org.openhab.myopenhab, component.id=192, service.config.description.uri=io:myopenhab, service.id=321, service.bundleid=208, service.scope=bundle} - org.openhab.io.myopenhab
2017-01-15 12:19:24.105 [DEBUG] [org.openhab.io.myopenhab ] - BundleEvent STARTED - org.openhab.io.myopenhab
2017-01-15 12:19:24.155 [DEBUG] [org.openhab.core ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.model.sitemap.SitemapProvider}={component.name=org.openhab.defaultsitemapprovider, component.id=193, service.id=322, service.bundleid=166, service.scope=bundle} - org.openhab.core
2017-01-15 12:19:24.270 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Manager.EVENT_TRANSPORT
2017-01-15 12:19:24.349 [DEBUG] [org.openhab.core ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.core, osgi.web.version=2.0.0.201701141030, osgi.web.contextpath=/, service.id=323, service.bundleid=166, service.scope=singleton} - org.openhab.core
2017-01-15 12:19:24.366 [DEBUG] [org.openhab.core ] - BundleEvent STARTING - org.openhab.core
2017-01-15 12:19:24.536 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Transport.EVENT_REQUEST_HEADERS
2017-01-15 12:19:25.648 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Manager.EVENT_TRANSPORT
2017-01-15 12:19:25.670 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Transport.EVENT_REQUEST_HEADERS
2017-01-15 12:19:25.965 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Transport.EVENT_REQUEST_HEADERS
2017-01-15 12:19:26.382 [DEBUG] [org.openhab.core ] - BundleEvent STARTED - org.openhab.core
2017-01-15 12:19:26.706 [ERROR] [o.myopenhab.internal.MyOpenHABClient] - Socket.IO error: not authorized
2017-01-15 12:19:26.710 [TRACE] [o.myopenhab.internal.MyOpenHABClient] - Transport.EVENT_REQUEST_HEADERS
I made one triple check and both secret and uuid are correct, and reinstalled the openhab 3 times. Something is missing but i cant figure out.
Regards,
Jaime
