In order to integrate my new Daikin Altherma 3 HT into openhab I had to buy a Zennio Klic DA Interface.
This interface works (I was the beta tester for Zennio) and connects the heatpump zo KNX.
Unfortunately the existing Daikin binding does not support my heatpump.
Now I have a problem displaying the temperature data that I get in Basic UI.
I had several different temperature sending devices in KNX and had no problem displaying them in BasicUI. The log shows that the data is transfered:
2022-12-22 11:30:28.623 [ome.event.ItemCommandEvent] - Item âflowtemperatureâ received command 58.68
In my items file
Number flowtemperature âVorlauftemperatur [%.1f °C]â (GF_Boiler, gHeating) {knx=â3/1/8â}
in my sitemap
Default item=flowtemperature label=âHZ Vorlauftemperaturâ
No data appears in the BasicUI
You are on openHAB 2.5, if I recall it correctly the âchannelâ syntax for the link of an item to the channel of a thing was used starting in version 2. Your item is using the older syntax for that ( "knxâŠ). Please check your thing on PaperUI in order to get the correct link syntax.
commands are not states.
BasicUI displays only states.
To see the effect of a command in the UI, either some binding must issue a state update; or, autoupdate must apply a prediction to state.
Autoupdate will not apply predictions where misconfigured channels exist.
As of knx1, all messages from the bus where recognized as commands. As openHAB does an autoUpdate, this did not result in problems (at least in question of state updates).
But as said, knx2 is available since OH2.3 (officially) and knx1 tends to mess up the openHAB 2 system, so itâs really the best option to get rid of this ancient binding.
Thank you all for your helpful comments. As I am planning to upgrade the binding anyway, I will use this event to finally do it. I will report back here when it is done.
