- Platform information:
- Hardware: RaspberryPi3B+
- OS: Raspian Bullseye
- Java Runtime Environment:
openjdk version "11.0.13" 2021-10-19 LTS
OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
OpenJDK Client VM Zulu11.52+13-CA (build 11.0.13+8-LTS, mixed mode)
- openHAB version: 3.1.1
I have an issue with YAML editing. Maybe someone can reproduce that and fix it:
I have created a Layout with several Blocks containing several cells. It looks quite similar to the demo-setup of openhab mainui her on the web.
now to shorten things a bit, i’ve configured the first cell and then simply put the yaml code into the next. cell and after clicking on done, the cell was set up according to the code.
for this cloned cell I wanted to edit some parts of the code, but unfortunately after clicking done, it’s not beeing saved.
Best Regards,
IvIax
