This link
https://community.openhab.org/c/actions
is taking me directly to an exception page.
where did you get it?
The correct one should be https://community.openhab.org/c/add-ons/actions
(since actions is a sub category of add-ons)
Sorry â from the home page of the community site under the Addons section, Actions.
Same applies to Other.
sorry for my ignorance ⊠could please post the URL on which you can see the broken URLs?
Itâs somehow corrected itself. I thought you had corrected it after my last reply.
On the home page, the Actions and Other buttons in the Add-ons section had incorrect links. They were both missing the /add-ons part of the URL. I reloaded the page in the browser and the broken URLs were corrected, which suggests that all my navigating around the site was AJAX-loading other parts, there was a stale cache somewhere, etc. Anyway, seems fixed now!
even better, thanks for the Update!
I still seem to have this issue - or a similar issue when trying to view the latest posts when a tag is selected. eg, select zwave in the tags, then select the Latest button, and it takes you to the following link.
https://community.openhab.org/tags/zwave/l/unreadThis page states that the link doesnât exist, or is privateâŠ
Chris
[quote=âchris, post:8, topic:1261, full:trueâ]
I still seem to have this issue[/quote]
Me too, see pics.
1: select z-wave
2: select latest
3. Error page
Weâll look into this.
It may or may not be related, but I often see âNew(1) Unread(1)â at the top of the page, but when I click on the New link, it tells me there are no new messages⊠It seems a little strange - or maybe I just misunderstand the meaning of ânewâ but even when there are new messages, it always says there arenât anyâŠ
Is it because I have email notifications enabled for all messages, or is there something amiss?
Chris
Actually, further to this, I just clicked on the âUnread(1)â link, and it told me this link didnât exist or was private (same error as per the messages above), so I guess this is all related to the same problem?
Chris
this seem to be a known bug (see https://meta.discourse.org/t/dismiss-unread-doesnt-clear-the-top-menu-unread-counter/13475/14)
Hmm - Iâm not sure if itâs the same. I pretty much never have any messages in New or Unread. It might tell me there are messages, but if I click on these buttons I normally get an error. Then if I click again, it tells me I have no unread (or new) messages. So itâs not that the number of new messages isnât resetting (which I think is the issue you referenced) itâs more that it doesnât seem to workâŠ
Cheers
Chris
thanks Chris! Strange ⊠this is working for me!
[quote=âteichsta, post:15, topic:1261, full:trueâ]
⊠this is working for me![/quote]
For me too ⊠sometimes it helps to clear the browser cache.
For me, itâs not working. I currently have a number of new messages - they show the blue new
label in the list of topics, but if I click on the New option, it tells me there are no new messages to listâŠ
So, at the moment, in the Latest menu, I have the following -:
But if I click on New, I get this -:
Maybe I just donât understand how itâs mean to work, but to me, the New menu should provide a list of all the messages with the blue new
label - is this a misunderstanding?
Chris
That is really strange âŠ
⊠I donât have those blue ânewâ marks anywhere, but as I read the welcome message again, it mentions something about those marks:
So if you have put something under âwatchedâ categories in your preferences it might explain the different behavior.
I have no watched, tracked or muted categories in my preferences.
If my assumption is correct, there is still the question if this is a bug or a feature
I donât have anything in the âwatchedâ config in my settings.
@Henry @teichsta - any thoughts on this? Itâs quite annoying as it basically means itâs not possible to get a list of new messages.
unfortunately not, sorry!
Could you try to create another user and see if it shows the same behaviour? If not Iâll the new user accordingly.
