first of all I’m a new in this area. I installed openhab on a raspi PI, according apt-get and HABmin1.
I’m using a AEOTEC Gen5 Stick it seems all is fine. HABmin shows the stick a node1 Zwave USB controller, light is green.
------------Number of Nodes Found Registered to ZWave Controller-------
Nodes = 1
So my next step was to insert the fibaro FGK-101 Door / Windows
opener by tripple clicking. I have 3 ones but all inserting tries
failed. I tried both options BACK button and internal tmp button. Reset doesn’t helped
sudo /etc/init.d/openhab status -l shows at the end of the output:
Node 1: Neighbor update failed several times
and
Node 255: Timeout while sending message Requiring 2 attempts.
During startup the only error message ist software reset is false?
These devices can be a bit tricky to include. You need to keep triple clicking until the Z-Stick flashes quickly to indicate successful inclusion. Can take a while and require very rapid clicking!
Thx I will try again … one question regarding the gen5 stick he is blinking and changing the led color from blue yellow etc. in a regular manner, is it normal behavior
It should be off by default, at least for my Zwave.me stick.
If you intend to use habmin for configuration changes (recommended), there is an option in your openhab.cfg:
zwave:softReset
Do not set it to true (it is false by default, so not using it at all should be okay)
I grow more and more desperate … in the meanwhile a have horny skin on my fingertips. Openhab and Habmin are stating without any error messages …but I don’t succeed in inserting the fibaro stuff.
One can we compare the content of the addons directory. I use …
pi@raspberrypi://usr/share/openhab/addons $ ls -l
insgesamt 2288
-rw-r–r-- 1 root root 1202164 Jan 10 22:14 org.openhab.binding.zwave-1.8.0.jar
-rw-r–r-- 1 pi pi 1134175 Okt 2 13:15 org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
-rw-r–r-- 1 root root 126 Jan 10 22:31 README
Do you think, it makes sense to compare other folders?
The only thing I don’t understand … I configured
#: sudo update-rc.d openhab defaults
doing only this, HABMIN doesn’t start I have additionally to to
sudo /etc/init.d/openhab start (Debian7, Wheez)
or
sudo systemctl start openhab (Debian 8, Jessie)
Habmin shows that mein gen5 Stick ises
API 1.0, zwave Version 3.95
Status Last packet send/receive none)
Node Stade alive done date …
Dead false
Listening true
one further question how do i revoke sudo update-rc.d openhab defaults?
you can start openhab manually with sudo /etc/init.d/openhab start or sudo systemctl start openhab depending on your linux distribution
You have to do this after every restart of your pi.
You can also configure your pi to automatically start openhab on reboot: sudo update-rc.d openhab defaults or sudo systemctl daemon-reload sudo systemctl enable openhab depending on your linux distribution.
This you only have to do once!
I read in another older post that people have had problems with the systemd options under Jessie, if that is also the problem in your case you should use the init versions:
sudo /etc/init.d/openhab start and sudo update-rc.d openhab defaults
To disable autostart of openhab you may use: update-rc.d openhab remove
