I have reset the socket and it was recognized by openhab as unkown zigbee device.
Does that mean, these devices are not yet supported?
Can I help to support them?
I don’t know about that socket. But what “bridge” are you using to connect to zigbeedevices? (HueBridge, Deconz,…) Does the “bridge” recognize and control the socket?
I use a Bitron Video BV 2010/10 coordinator.
It detects the socket as generic USB device. I found a channel for the switch but when I link it to an item I can not control it.
The socket shows Online at some point but when I try to controll it, it then shows Offline.
Generally I wouldn’t expect any issues. Have you checked the logging to see what is happening? This should clearly be your next step (as per the binding documentation ).
What version of the firmware are you running. With ZB3.0 devices, you will need firmware greater than 6.4 (if I remember correctly) otherwise the device will leave the network after it joins as it doesn’t meet the security requirements.
