I am running openHABian v1.6.5 on a RPi 3 with an Aeotec Z-Stick Gen5 and I am having problems setting some configuration parameters on a Fibaro Smart Implant FGBS-222. I have searched for posts about this device but none found concern my particular problem.
I want to set parameters 40 and 41 to allow all possible scenes to be sent. The description says “This is a BIT flag allowing all options to be set” but in the Thing’s Configuration Parameters section, the 4 options are represented by radio buttons of which only one can be pressed at a time. From my understanding, I think these should be check boxes (not radio buttons) so any number can be selected.
I am happy to contribute by attempting to fix this but I would need some pointers to where the code for generating this part of the UI is located. Alternatively, perhaps someone familiar with the code could fix it very quickly.
I am a newcomer to openHab and am enjoying learning about it and using it to control several Z-Wave devices and Hue bulbs. I wasn’t sure if this post should be in the UI section or maybe even Development so I’m sorry if it’s in the wrong place.
Thank you for suggesting that workaround. I had completely forgotten the Code Tab. Great feature! I will try it out and also file an issue (I don’t think it has been filed before). Thanks again for your help.
