Hi im trying to integrate econz with openhab but i think im missing something.
I have set up deconz on a docler container using a ready image. Everything looks fine there. I can find my switches and lights. In openhab i intall the decon binding an the hue bridge binding. After entering the ip and port in the deconz binding it shows status online. The hue bridge itself discovered the deconz instance and i add it. The hue bridge first shows a communication error until I allow api access, ut then it only shows status offline.
I guess the fact that hue shows offline is the problem.
The log shows java.net.ConnectException: Connection refused (Connection refused)
None of my lights and switches show up on dicovery in openhab paperui.
I have gotten closer to the goal. The hue bridge now connects after changing the deconz instance to port 80. Lights are discovered through the hue bridge.
The deconz binding shows as online but is not discovering any switches. I get the following error message in the debug logs
java.lang.IllegalStateException: Destroyed container cannot be restarted
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:93) ~[?:?]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStart(WebSocketClient.java:409) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[?:?]
at org.openhab.binding.deconz.internal.netutils.WebSocketConnection.start(WebSocketConnection.java:59) ~[?:?]
at org.openhab.binding.deconz.internal.handler.DeconzBridgeHandler.startWebsocket(DeconzBridgeHandler.java:224) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
23:39:47.882 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler DeconzBridgeHandler tried updating the thing status although the handler was already disposed.
In my case I run both Openhab and Deconz in two seperate containers, and I end up solving it with this setting:
Deconz container> bridge host port 8083 (or whichever port suitabale) to container port 80
In Openhab container> specifying the Deconz thing configuration to use 172.17.0.1(host):8083 to connect to deconz, then it works.
I guess what happened before was that docker container network gave a different dynamic fictional IP each time and when I restart containers, it broke the thing setting.
