Hi all,
I am having some issues setting up Tado into my OH
- I have created a file called tado.things with the following contents
Bridge tado:home:heating [ username="my username", password="mypassword" ] {
zone room1 [id=1]
zone room2 [id=2]
zone room3 [id=3]
zone room4 [id=4]
zone warmwater [id=0]
mobiledevice phone [id=1223394]
And a second file called tado.items with the following contents
Switch Battery_Low_Alarm "Battery Low Alarm" { channel="tado:zone:heating:hotwater:batteryLowAlarm" }
Number:Temperature HEAT_inside_temperature "Inside Temperature" { channel="tado:zone:heating:room1:currentTemperature" }
Number HEAT_humidity "Humidity" { channel="tado:zone:heating:room1:humidity" }
Number HEAT_heating_power "Heating Power" { channel="tado:zone:heating:room1:heatingPower" }
String HEAT_hvac_mode "HVAC Mode" { channel="tado:zone:heating:room1:hvacMode" }
Number:Temperature HEAT_target_temperature "Set Point" { channel="tado:zone:heating:room1:targetTemperature" }
DateTime HEAT_overlay_expiry "Overlay Expiry" { channel="tado:zone:heating:room1:overlayExpiry" }
Number HEAT_timer_duration "Timer Duration" { channel="tado:zone:heating:room1:timerDuration" }
String HEAT_operation_mode "Operation Mode" { channel="tado:zone:heating:room1:operationMode" }
Switch Battery_Low_Alarm "Battery Low Alarm" { channel="tado:zone:heating:room1:batteryLowAlarm" }
Number:Temperature HEAT_inside_temperature "Inside Temperature" { channel="tado:zone:heating:room2:currentTemperature" }
Number HEAT_humidity "Humidity" { channel="tado:zone:heating:room2:humidity" }
Number HEAT_heating_power "Heating Power" { channel="tado:zone:heating:room2:heatingPower" }
String HEAT_hvac_mode "HVAC Mode" { channel="tado:zone:heating:room2:hvacMode" }
Number:Temperature HEAT_target_temperature "Set Point" { channel="tado:zone:heating:room2:targetTemperature" }
DateTime HEAT_overlay_expiry "Overlay Expiry" { channel="tado:zone:heating:room2:overlayExpiry" }
Number HEAT_timer_duration "Timer Duration" { channel="tado:zone:heating:room2:timerDuration" }
String HEAT_operation_mode "Operation Mode" { channel="tado:zone:heating:room2:operationMode" }
Switch Battery_Low_Alarm "Battery Low Alarm" { channel="tado:zone:heating:room2:batteryLowAlarm" }
Number:Temperature HEAT_inside_temperature "Inside Temperature" { channel="tado:zone:heating:room3:currentTemperature" }
Number HEAT_humidity "Humidity" { channel="tado:zone:heating:room3:humidity" }
Number HEAT_heating_power "Heating Power" { channel="tado:zone:heating:room3:heatingPower" }
String HEAT_hvac_mode "HVAC Mode" { channel="tado:zone:heating:room3:hvacMode" }
Number:Temperature HEAT_target_temperature "Set Point" { channel="tado:zone:heating:room3:targetTemperature" }
DateTime HEAT_overlay_expiry "Overlay Expiry" { channel="tado:zone:heating:room3:overlayExpiry" }
Number HEAT_timer_duration "Timer Duration" { channel="tado:zone:heating:room3:timerDuration" }
String HEAT_operation_mode "Operation Mode" { channel="tado:zone:heating:room3:operationMode" }
Switch Battery_Low_Alarm "Battery Low Alarm" { channel="tado:zone:heating:room3:batteryLowAlarm" }
Number:Temperature HEAT_inside_temperature "Inside Temperature" { channel="tado:zone:heating:room4:currentTemperature" }
Number HEAT_humidity "Humidity" { channel="tado:zone:heating:room4:humidity" }
Number HEAT_heating_power "Heating Power" { channel="tado:zone:heating:room4:heatingPower" }
String HEAT_hvac_mode "HVAC Mode" { channel="tado:zone:heating:room4:hvacMode" }
Number:Temperature HEAT_target_temperature "Set Point" { channel="tado:zone:heating:room4:targetTemperature" }
DateTime HEAT_overlay_expiry "Overlay Expiry" { channel="tado:zone:heating:room4:overlayExpiry" }
Number HEAT_timer_duration "Timer Duration" { channel="tado:zone:heating:room4:timerDuration" }
String HEAT_operation_mode "Operation Mode" { channel="tado:zone:heating:room4:operationMode" }
Switch Battery_Low_Alarm "Battery Low Alarm" { channel="tado:zone:heating:room4:batteryLowAlarm" }
My problem:
If I look in OH under Control, I see 4 zones with all the same values. What am I forgetting and or doing wrong?
2nd question:
Do I need to create a different sitemap or can I include it into an already active sitemap?
Many thanks in advance!
