I’m using a raspberry pi 2 with openhab 1.8.3 and have registered to myopenhab.
Logging into myopenhab.org works fine: status is online, I can use the sitemap I have defined as if it were local, so no issues there.
However: I have an IP camera which works fine when using openhab through my local network, but through myopenhab.org I don’t get any image (don’t get any error in the log either).
Also: I have a weatherforecast which also works fine when accessed locally but no images when used through myopenhab.org.
The icons show perfectly as well as the graphs I generate using RR4DJ (both locally as through myopenhab.org).
I read something about exposing the items, but I don’t think that would be necessary in my case.
I did indeed forgeet to copy the sitemap definition (and since I am at the office right now, I’m not able to copy it in).
However: the RRD4J graphs as well as the Ip camera are referenced by a local ip address (192.x.x.x). As mentioned: the RRD4J graphs show nicely but the IP cam imaged doesn’t. Is there a difference in the way these are handled?
All seems to be related to the ‘webview url’. I did change the Webview url to an ‘image url’ and… the IP camera is working. I assume the weather forecast will have the same solution. If I get it working, I will post it… if not…
