I run an openhab 3 installation on a RPI4 and everything run fine.
I have many Xiaomi sensors and Zigbee plugs.
I’m on the road to remove my Philips Hue Bridge to put everything on OH3.
I’m able to control the light, brightness, color and everything. The only problem I have is that I didn’t achieve to retrieve in openhab the current color of the light. I can see with mqttexplorer interesting topic for the bulb :
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/brightness', payload '153'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color-h', payload '200'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color_temp', payload '590'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color-s', payload '100'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/linkquality', payload '125'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color-v', payload '80'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/state', payload 'ON'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color-x', payload '0.562267438989995'
info 2021-11-13 21:55:48: MQTT publish: topic 'zigbee2mqtt/LIGHT_HUE_STRIP_1/color-y', payload '0.403822425671539'
I see many things for the color but in two topic if i want to get it from XY or three if i want to get it from HSB.
What is the best way to get the current color of a RGB bulb in Openhab from MQTT ?
MQTT binding color type channel has capabilities for RGB or HSB or XYY
On looking at the MQTT you’re considering though, you won’t be able to get of that to work because your information is sent across different topics.
Going to have to load to separate working Items, and combine to a color type in a rule.
I think you can get the info more usefully in one MQTT payload though
