I have just updated my Openhabian from v3.4.5 to v4.1. Everything seems to work fine but when I call up a part of my sitemap, I get errors that I don’t quite know what to do with.
These are texts that are made visible depending on a string item with different replacement texts on the right side.
By placing the replacement text in the square brackets, the replacement text always appears right-aligned, just like the original value.
In v3.4.5 this was not a problem, how could I adjust this in v4.1 to achieve the same behaviour without warning ?
Number:Temperature IFO2R_Dest "Soll [%.1f °C]" <temperature> (IFO2_Radiator,OG_RadiatorDestinations) ["Temperature"] { unit="°C", channel="zwave:device:z_wave_ctrl_01:node97:thermostat_setpoint_heating" }
Text item=IFO2R_Dest label="Betriebsart: 'Tag' [(soll = %.1f °C)]" visibility=[IFO2R_Mode_Valve=="Tag"] icon="temperature_hot"
Text item=IFO2R_Dest label="Betriebsart: 'Nacht' [(soll = %.1f °C)]" visibility=[IFO2R_Mode_Valve=="Nacht"] icon="temperature_cold"
Text item=IFO2R_Dest label="Betriebsart: 'Aus' [(soll = --- °C)]" visibility=[IFO2R_Mode_Valve=="Aus"] icon="temperature_off"
Text item=IFO2R_Dest label="Betriebsart: 'Heizen' [(soll = 100 °C)]" visibility=[IFO2R_Mode_Valve=="Heizen"] icon="temperature_veryhot"
Text item=IFO2R_Dest label="Betriebsart: 'Manuell' [(soll = %.1f °C)]" visibility=[IFO2R_Mode_Valve=="Manuell"] icon="temperature_hot"
Text item=IFO2R_Dest label="'Fenster auf' [Heizung aus]" visibility=[IFO2R_Mode_Valve=="FensterAuf"] icon="openwindow"
Text item=IFO2R_Dest label="'Sommerabschaltung' [Heizung aus]" visibility=[IFO2R_Mode_Valve=="Sommerabschaltung"] icon="temperature_off"
2024-01-02 17:03:31.275 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = --- °C)', dropping postfix
2024-01-02 17:03:31.277 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = --- °C)', dropping postfix
2024-01-02 17:03:31.278 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = --- °C)', dropping postfix
2024-01-02 17:03:31.279 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = --- °C)', dropping postfix
2024-01-02 17:03:31.281 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = 100 °C)', dropping postfix
2024-01-02 17:03:31.282 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = 100 °C)', dropping postfix
2024-01-02 17:03:31.283 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = 100 °C)', dropping postfix
2024-01-02 17:03:31.284 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern '(soll = 100 °C)', dropping postfix
2024-01-02 17:03:31.287 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.289 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.290 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.291 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.292 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.293 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.294 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
2024-01-02 17:03:31.295 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Item 'IFO2R_Dest' with unit, nothing allowed after unit in label pattern 'Heizung aus', dropping postfix
