sipvoip
(Nathan Stratton)
November 25, 2017, 6:26pm
1
I am runing latest 2.2 SNAP with Sep 18 16:08 org.openhab.binding.zwave-2.1.0-SNAPSHOT.jar things basically work and my network looks good other than 2 dead battery nodes.
My items are all manually configured and look like:
Thing zwave:rtc_ct100_00_000:controller:node6 "Node 6: CT100 - Master Bedroom" (zwave:serial_zstick:controller) [ node_id=6 ] {
Channels:
Type sensor_temperature : sensor_temperature [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_cooling [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_heating [ config_scale=1 ]
The problem I am running into is that many of the stats temp will change and it does not update openhab. This is a real issue because openhab controls the dampers for HVAC!
My understanding is that I should get an update on ever event and temp change on each state, since that is not working, is there a way to at least poll every 30 min or so with static configs?
sipvoip
(Nathan Stratton)
November 26, 2017, 8:20pm
2
Thanks! I now see Polling, but no temp returned.
zwave.log:26-Nov-2017 10:46:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 10:56:01.906 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:06:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:16:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:26:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:36:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:46:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 11:56:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:06:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:16:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:26:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:36:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:46:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 12:56:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 13:06:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 13:16:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 13:26:01.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
zwave.log:26-Nov-2017 13:36:01.884 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 13: Polling...
