Problems with Fibaro Double Switch in OH3
- Platform information:
- Hardware: PC
- OS: Windows11
- Java Runtime Environment: openjdk version “11.0.12”
- openHAB version: 3.2.0
Hello. I’m having a strange issue with my FIbaro Double Switch 223.
The switch is connected directly to a light switch. When I toggle the light switch manually, I can turn on and off the light and I can also receive state updates in OH3 UI.
However, when I send the command from OH3 to change the state, the command is ignored. The OH3 toggle switches ON and then back OFF in a couple of seconds.
If I launch the OH2 on the same PC with same hardware then everything works fine.
I captured ZWAve logs and hope somebody can shed some light of what is going on. Note the Node35 below
2022-06-12 19:04:05.133 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Command received zwave:device:466d9b93a7:node35:switch_binary1 --> ON [OnOffType]
2022-06-12 19:04:05.133 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 35: Creating new message for application command SWITCH_BINARY_SET
2022-06-12 19:04:05.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Encapsulating message, instance / endpoint 1
2022-06-12 19:04:05.133 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 35: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-06-12 19:04:05.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-06-12 19:04:05.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-06-12 19:04:05.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Adding to device queue
2022-06-12 19:04:05.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Added 272 to queue - size 1
2022-06-12 19:04:05.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:05.134 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 13 23 07 60 0D 01 01 25 01 FF 25 DD 88
2022-06-12 19:04:05.134 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 35: Sending REQUEST Message = 01 0E 00 13 23 07 60 0D 01 01 25 01 FF 25 DD 88
2022-06-12 19:04:05.136 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-06-12 19:04:05.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 272: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 221
2022-06-12 19:04:05.136 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling initialised at 1800 seconds - start in 15000 milliseconds.
2022-06-12 19:04:07.137 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 35: TID 272: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2022-06-12 19:04:07.137 [DEBUG] [sactionManager$ZWaveTransactionTimer] - Aborting Transaction!
2022-06-12 19:04:07.137 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 272: Transaction ABORTED
2022-06-12 19:04:07.137 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2022-06-12 19:04:07.137 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
2022-06-12 19:04:07.139 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 272: [ABORTED] priority=Set, requiresResponse=true, callback: 221
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:07.139 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-06-12 19:04:07.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:18.037 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 1A 0E 32 02 21 44 00 00 04 82 01 2D 00 00 04 82 82
2022-06-12 19:04:18.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0E 32 02 21 44 00 00 04 82 01 2D 00 00 04 82
2022-06-12 19:04:18.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0E 32 02 21 44 00 00 04 82 01 2D 00 00 04 82
2022-06-12 19:04:18.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 272: [ABORTED] priority=Set, requiresResponse=true, callback: 221
2022-06-12 19:04:18.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:18.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:18.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-06-12 19:04:18.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2022-06-12 19:04:18.038 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 26: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-06-12 19:04:18.039 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 26: Meter: Type=Electric(1), Scale=kWh(0), Value=11.54
2022-06-12 19:04:18.039 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-06-12 19:04:18.039 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=11.54
2022-06-12 19:04:18.039 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Updating channel state zwave:device:466d9b93a7:node26:meter_kwh to 11.54 [DecimalType]
2022-06-12 19:04:18.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Commands processed 1.
2022-06-12 19:04:18.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2de25cec.
2022-06-12 19:04:18.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-06-12 19:04:18.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:18.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:19.027 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 1A 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 92
2022-06-12 19:04:19.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00
2022-06-12 19:04:19.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00
2022-06-12 19:04:19.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 272: [ABORTED] priority=Set, requiresResponse=true, callback: 221
2022-06-12 19:04:19.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:19.028 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:19.028 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-06-12 19:04:19.028 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2022-06-12 19:04:19.028 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 26: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-06-12 19:04:19.028 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 26: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
2022-06-12 19:04:19.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-06-12 19:04:19.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0E+1
2022-06-12 19:04:19.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Updating channel state zwave:device:466d9b93a7:node26:meter_watts to 0 [DecimalType]
2022-06-12 19:04:19.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Commands processed 1.
2022-06-12 19:04:19.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@337efe46.
2022-06-12 19:04:19.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-06-12 19:04:19.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:19.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:19.138 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 35: TID 272: Timeout at state ABORTED. 3 retries remaining.
2022-06-12 19:04:19.138 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 272: Transaction is current transaction, so clearing!!!!!
2022-06-12 19:04:19.138 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 272: Transaction CANCELLED
2022-06-12 19:04:19.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-06-12 19:04:19.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: notifyTransactionResponse TID:272 CANCELLED
2022-06-12 19:04:19.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:20.024 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 1A 0A 32 02 A1 42 2F 65 01 2D 2F 49 28
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0A 32 02 A1 42 2F 65 01 2D 2F 49
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0A 32 02 A1 42 2F 65 01 2D 2F 49
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:20.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:20.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-06-12 19:04:20.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2022-06-12 19:04:20.025 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 26: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-06-12 19:04:20.025 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 26: Meter: Type=Electric(1), Scale=V(4), Value=121.33
2022-06-12 19:04:20.025 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-06-12 19:04:20.025 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=121.33
2022-06-12 19:04:20.025 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Updating channel state zwave:device:466d9b93a7:node26:meter_voltage to 121.33 [DecimalType]
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Commands processed 1.
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@702f609e.
2022-06-12 19:04:20.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-06-12 19:04:20.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:20.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling...
2022-06-12 19:04:20.173 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling zwave:device:466d9b93a7:node35:switch_binary1
2022-06-12 19:04:20.173 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 35: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2022-06-12 19:04:20.173 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 35: Creating new message for application command SWITCH_BINARY_GET
2022-06-12 19:04:20.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Encapsulating message, instance / endpoint 1
2022-06-12 19:04:20.173 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 35: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-06-12 19:04:20.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-06-12 19:04:20.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-06-12 19:04:20.174 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling skipped for zwave:device:466d9b93a7:node35:switch_binary1 on COMMAND_CLASS_BASIC
2022-06-12 19:04:20.174 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling zwave:device:466d9b93a7:node35:switch_binary2
2022-06-12 19:04:20.174 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 35: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 2
2022-06-12 19:04:20.174 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 35: Creating new message for application command SWITCH_BINARY_GET
2022-06-12 19:04:20.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Encapsulating message, instance / endpoint 2
2022-06-12 19:04:20.174 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 35: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2022-06-12 19:04:20.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-06-12 19:04:20.174 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Polling skipped for zwave:device:466d9b93a7:node35:switch_binary2 on COMMAND_CLASS_BASIC
2022-06-12 19:04:20.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Adding to device queue
2022-06-12 19:04:20.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Added 273 to queue - size 1
2022-06-12 19:04:20.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:20.174 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 23 06 60 0D 01 01 25 02 25 DE 75
2022-06-12 19:04:20.174 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 35: Sending REQUEST Message = 01 0D 00 13 23 06 60 0D 01 01 25 02 25 DE 75
2022-06-12 19:04:20.176 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-06-12 19:04:20.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 273: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Adding to device queue
2022-06-12 19:04:20.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Added 274 to queue - size 1
2022-06-12 19:04:20.177 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-06-12 19:04:20.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:20.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:20.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 273: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-06-12 19:04:20.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:20.182 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-06-12 19:04:20.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 273: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-06-12 19:04:20.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 273: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.183 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.186 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 35: sentData successfully placed on stack.
2022-06-12 19:04:20.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 273: Advanced to WAIT_REQUEST
2022-06-12 19:04:20.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: TID 273: Transaction not completed
2022-06-12 19:04:20.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:20.263 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 DE 00 00 08 3D
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=222, payload=DE 00 00 08
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=222, payload=DE 00 00 08
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 273: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 273: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 222
2022-06-12 19:04:20.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 273: (Callback 222)
2022-06-12 19:04:20.265 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-06-12 19:04:20.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 273: callback 222
2022-06-12 19:04:20.265 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=222, payload=DE 00 00 08
2022-06-12 19:04:20.265 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 35: SendData Request. CallBack ID = 222, Status = Transmission complete and ACK received(0)
2022-06-12 19:04:20.265 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:20.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 273: Advanced to WAIT_DATA
2022-06-12 19:04:20.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: TID 273: Transaction not completed
2022-06-12 19:04:20.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.266 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:20.347 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 23 07 60 0D 01 01 25 03 00 99
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=35, callback=0, payload=00 23 07 60 0D 01 01 25 03 00
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=35, callback=0, payload=00 23 07 60 0D 01 01 25 03 00
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:20.348 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:20.348 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-06-12 19:04:20.348 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2022-06-12 19:04:20.348 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2022-06-12 19:04:20.348 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 35: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2022-06-12 19:04:20.348 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 35: Switch Binary report, value = 0
2022-06-12 19:04:20.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-06-12 19:04:20.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_BINARY, value=0
2022-06-12 19:04:20.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Updating channel state zwave:device:466d9b93a7:node35:switch_binary1 to OFF [OnOffType]
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Commands processed 1.
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7ba30153.
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7ba30153.
2022-06-12 19:04:20.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: notifyTransactionResponse TID:273 DONE
2022-06-12 19:04:20.349 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-06-12 19:04:20.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-06-12 19:04:20.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-06-12 19:04:20.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:20.349 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 23 06 60 0D 01 02 25 02 25 DF 77
2022-06-12 19:04:20.349 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 35: Sending REQUEST Message = 01 0D 00 13 23 06 60 0D 01 02 25 02 25 DF 77
2022-06-12 19:04:20.350 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-06-12 19:04:20.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 274: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 223
2022-06-12 19:04:20.351 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-06-12 19:04:20.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:20.359 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-06-12 19:04:20.360 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 274: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 223
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 274: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 223
2022-06-12 19:04:20.364 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-06-12 19:04:20.364 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 35: sentData successfully placed on stack.
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 274: Advanced to WAIT_REQUEST
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: TID 274: Transaction not completed
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:20.498 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 DF 00 00 0E 3A
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=223, payload=DF 00 00 0E
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=223, payload=DF 00 00 0E
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 274: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 223
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 274: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 223
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 274: (Callback 223)
2022-06-12 19:04:20.499 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 274: callback 223
2022-06-12 19:04:20.499 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=223, payload=DF 00 00 0E
2022-06-12 19:04:20.499 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 35: SendData Request. CallBack ID = 223, Status = Transmission complete and ACK received(0)
2022-06-12 19:04:20.499 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 274: Advanced to WAIT_DATA
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: TID 274: Transaction not completed
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-06-12 19:04:20.581 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 23 07 60 0D 02 01 25 03 00 9A
2022-06-12 19:04:20.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=35, callback=0, payload=00 23 07 60 0D 02 01 25 03 00
2022-06-12 19:04:20.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=35, callback=0, payload=00 23 07 60 0D 02 01 25 03 00
2022-06-12 19:04:20.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-06-12 19:04:20.586 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:20.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:20.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-06-12 19:04:20.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 2
2022-06-12 19:04:20.587 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 35: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2022-06-12 19:04:20.587 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 35: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2022-06-12 19:04:20.587 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 35: Switch Binary report, value = 0
2022-06-12 19:04:20.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-06-12 19:04:20.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_SWITCH_BINARY, value=0
2022-06-12 19:04:20.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Updating channel state zwave:device:466d9b93a7:node35:switch_binary2 to OFF [OnOffType]
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Commands processed 1.
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@441937f7.
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@441937f7.
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 35: notifyTransactionResponse TID:274 DONE
2022-06-12 19:04:20.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 35: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:20.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-06-12 19:04:21.024 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 1A 0A 32 02 A1 4A 00 00 01 2D 00 00 0C
2022-06-12 19:04:21.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0A 32 02 A1 4A 00 00 01 2D 00 00
2022-06-12 19:04:21.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=26, callback=0, payload=00 1A 0A 32 02 A1 4A 00 00 01 2D 00 00
2022-06-12 19:04:21.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-06-12 19:04:21.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Application Command Request (ALIVE:DONE)
2022-06-12 19:04:21.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2022-06-12 19:04:21.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-06-12 19:04:21.025 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2022-06-12 19:04:21.026 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 26: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-06-12 19:04:21.026 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 26: Meter: Type=Electric(1), Scale=A(5), Value=0E+1
2022-06-12 19:04:21.026 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-06-12 19:04:21.026 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0E+1
2022-06-12 19:04:21.026 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Updating channel state zwave:device:466d9b93a7:node26:meter_current to 0 [DecimalType]
2022-06-12 19:04:21.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Commands processed 1.
2022-06-12 19:04:21.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@516dfc.
2022-06-12 19:04:21.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-06-12 19:04:21.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-06-12 19:04:21.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
