Hi Gerald, many thanks for your reply.
If I request as mentioned the thing is not found.
Output:
{"error":{"message":"Thing homematic:HM-ES-TX-WM:RF-c1e6902b:NEQ0863610 does not exist!","http-code":404}}
I got confused.
Maybe this is not relevant, but I modified the request a little bit to be according to my naming. I just removed this “RF-” prefix before the name of my bridge. Then I get the following output:
{"statusInfo":{"status":"OFFLINE","statusDetail":"COMMUNICATION_ERROR","description":"-1 Failure (sending \u003c?xml version\u003d\"1.0\" encoding\u003d\"ISO-8859-1\"?\u003e\n\u003cmethodCall\u003e\u003cmethodName\u003egetValue\u003c/methodName\u003e\n\u003cparams\u003e\u003cparam\u003e\u003cvalue\u003eNEQ0863610:1\u003c/value\u003e\u003c/param\u003e\u003cparam\u003e\u003cvalue\u003eIEC_POWER\u003c/value\u003e\u003c/param\u003e\u003c/params\u003e\u003c/methodCall\u003e)"},"editable":true,"label":"Stromzaehler","bridgeUID":"homematic:bridge:c1e6902b","configuration":{"HMP_1_ENERGY_COUNTER_STRING":"","HMP_2_POWER_STRING":"","HMP_1_AES_ACTIVE":false,"HMP_1_METER_CONSTANT_GAS":0.01,"HMP_1_POWER_STRING":"","HMP_2_TX_THRESHOLD_POWER":100.0,"HMP_2_AES_ACTIVE":false,"HMP_1_METER_SENSIBILITY_IR":0,"HMP_1_TX_THRESHOLD_POWER":100.0,"HMP_1_METER_TYPE":"IR-SENSOR","HMP_1_METER_CONSTANT_IR":100,"HMP_2_ENERGY_COUNTER_STRING":"","HMP_1_METER_CONSTANT_LED":10000,"HMP_2_METER_TYPE":"4"},"properties":{"serialNumber":"NEQ0863610","modelId":"HM-ES-TX-WM","vendor":"eQ-3 AG","aesKey":"0","firmwareVersion":"1.2","batteryType":"4x AA/Mignon/LR06"},"UID":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610","thingTypeUID":"homematic:HM-ES-TX-WM","channels":[{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#CONFIG_PENDING","id":"0#CONFIG_PENDING","channelTypeUID":"homematic:HM-ES-TX-WM_0_CONFIG_PENDING","itemType":"Switch","kind":"STATE","label":"Config Pending","description":"Zeigt eine ausstehende Konfigurations Aktualisierung an","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#RSSI_DEVICE","id":"0#RSSI_DEVICE","channelTypeUID":"homematic:HM-ES-TX-WM_0_RSSI_DEVICE","itemType":"Number","kind":"STATE","label":"Rssi Device","description":"Empfangsstärke","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#DELETE_DEVICE_MODE","id":"0#DELETE_DEVICE_MODE","channelTypeUID":"homematic:HM-ES-TX-WM_0_DELETE_DEVICE_MODE","itemType":"String","kind":"STATE","label":"Delete Device Mode","description":"Löschmodus","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#DEVICE_IN_BOOTLOADER","id":"0#DEVICE_IN_BOOTLOADER","channelTypeUID":"homematic:HM-ES-TX-WM_0_DEVICE_IN_BOOTLOADER","itemType":"Switch","kind":"STATE","label":"Device In Bootloader","description":"Gerät im bootloader","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#UPDATE_PENDING","id":"0#UPDATE_PENDING","channelTypeUID":"homematic:HM-ES-TX-WM_0_UPDATE_PENDING","itemType":"Switch","kind":"STATE","label":"Update Pending","description":"Zeigt eine ausstehende Aktualisierung an","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#FIRMWARE","id":"0#FIRMWARE","channelTypeUID":"homematic:HM-ES-TX-WM_0_FIRMWARE","itemType":"String","kind":"STATE","label":"Firmware","description":"Version der Firmware","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#RSSI_PEER","id":"0#RSSI_PEER","channelTypeUID":"homematic:HM-ES-TX-WM_0_RSSI_PEER","itemType":"Number","kind":"STATE","label":"Rssi Peer","description":"Signalstärke Peer","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#BATTERY_TYPE","id":"0#BATTERY_TYPE","channelTypeUID":"homematic:HM-ES-TX-WM_0_BATTERY_TYPE","itemType":"String","kind":"STATE","label":"Battery Type","description":"Typ der Batterie","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#UNREACH","id":"0#UNREACH","channelTypeUID":"homematic:HM-ES-TX-WM_0_UNREACH","itemType":"Switch","kind":"STATE","label":"Unreach","description":"Gerätekommunikationsstatus","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":["StromzaehlerSignalStaerke"],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#SIGNAL_STRENGTH","id":"0#SIGNAL_STRENGTH","channelTypeUID":"system:signal-strength","itemType":"Number","kind":"STATE","label":"Signalstärke","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["StromzaehlerBatterieLeer"],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#LOWBAT","id":"0#LOWBAT","channelTypeUID":"system:low-battery","itemType":"Switch","kind":"STATE","label":"Niedriger Batteriestatus","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#RSSI","id":"0#RSSI","channelTypeUID":"homematic:HM-ES-TX-WM_0_RSSI","itemType":"Number","kind":"STATE","label":"Rssi","description":"Vereinheitlichte Empfangsstärke","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#DELETE_DEVICE","id":"0#DELETE_DEVICE","channelTypeUID":"homematic:HM-ES-TX-WM_0_DELETE_DEVICE","itemType":"Switch","kind":"STATE","label":"Delete Device","description":"Gerät löschen","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:0#STICKY_UNREACH","id":"0#STICKY_UNREACH","channelTypeUID":"homematic:HM-ES-TX-WM_0_STICKY_UNREACH","itemType":"Switch","kind":"STATE","label":"Sticky Unreach","description":"Gerätekommunikationsstatus","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:1#BOOT","id":"1#BOOT","channelTypeUID":"homematic:HM-ES-TX-WM_1_BOOT","itemType":"Switch","kind":"STATE","label":"Boot","description":"Boot","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":["StromVerbrauchAktuell","Stromzaehler_1_Power"],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:1#POWER","id":"1#POWER","channelTypeUID":"homematic:HM-ES-TX-WM_1_POWER","itemType":"Number","kind":"STATE","label":"Power","description":"Leistung","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:1#GAS_ENERGY_COUNTER","id":"1#GAS_ENERGY_COUNTER","channelTypeUID":"homematic:HM-ES-TX-WM_1_GAS_ENERGY_COUNTER","itemType":"Number","kind":"STATE","label":"Gas Energy Counter","description":"Energie Gas-Zähler Gerät","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":[],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:1#GAS_POWER","id":"1#GAS_POWER","channelTypeUID":"homematic:HM-ES-TX-WM_1_GAS_POWER","itemType":"Number","kind":"STATE","label":"Gas Power","description":"Gas Verbrauch","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}},{"linkedItems":["StromVerbrauchGesamt","Stromzaehler_1_EnergyCounter"],"uid":"homematic:HM-ES-TX-WM:c1e6902b:NEQ0863610:1#ENERGY_COUNTER","id":"1#ENERGY_COUNTER","channelTypeUID":"homematic:HM-ES-TX-WM_1_ENERGY_COUNTER","itemType":"Number","kind":"STATE","label":"Energy Counter","description":"Energie-Zähler Gerät","defaultTags":[],"properties":{},"configuration":{"receiveDelay":0.0,"delay":0.0}}],"location":"Waschhaus"}
This is looking maybe more like the output you’ve expected.
Kind regards Kay.
PS: This problem occured under OH2.2. After a reboot of the pi which drives OH and some other services like influx and mariadb because of some hangs (after file system was full) most of the “things” added formerly with paperui disappeared. To repair this damage I added these things now with some things files.
Behind of the brigde (even a raspi) many other things and items are working now as in the past - except this energy meter. Because of some other problems in OH2.2 with the also used milight binding I upgraded to OH2.3 - with no difference for this problem.
